Tip & How-To about Computers & Internet
How to align an adsense widget on a blogger website
Edit the HTML template then click the check box in Expand Widgets Template box at top right of Edit Template text box either scroll down OR I always use Ctrl+F type in the code
If you have multiple adsense widgets they will be sequential ie adsense1, adsense2,...... it will be trial and error to find the one you require or you could just align all of them to make it easier.
Computers & Internet Logo
how do i post an away message
  • After you create the automatic reply message and set up the filter, you must leave your computer running and Outlook open in order for the message to work.
  • using the method below to set a rule that sends reply messages to all senders except those who are posting to a LISTSERV list. This prevents reply messages from being sent to everyone on a list.
  • Outlook's Out of Office Assistant tool is another option for setting an automatic reply message; however, you cannot set rules for specific mail, such as LISTSERV lists.
  • If setting a rule is not necessary, instructions on using the Out of Office Assistant can be found on Microsoft's How to Use the Out of Office Assistant in Outlook Web page.
To create and use an automatic reply message:
  1. Create an away message.
    • In 2007, at the top left of the window, click the New button.
    1. In the body of the message, type the away message you want to use.
    2. Save the message.
      • In 2007:
        1. Click the Office Button.
        2. From the drop-down list, select Save As.
    3. From the Save as type: drop-down list, select Outlook Template (*.oft).
    4. In the File name: text box, type: away
    5. Save the file to your desktop.
    6. Close the message window.
    7. Click the No button.
  2. To use your away message, set up an automatic reply filter.
    1. From the Tools menu, select Rules and Alerts....
    2. Click the New Rule... button.
    3. From the list, select Check messages when they arrive.
    4. Click Next.
    5. Click Next.
    6. Click the Yes button.
    7. Under Step 1: Select action(s), place a check in the reply using a specific template check box.
    8. Under Step 2: Edit the rule description (click an underlined value), click the a specific template link.
    9. From the Look In: drop-down list, select User Templates in File System.
    10. Click the Browse... button.
    11. Navigate to your desktop.
    12. Click OK.
    13. From the list, select the away message template.
    14. Click the Open button.
    15. Click Next.
  3. Set up the rule to create exceptions where LISTSERV is in the recipient's address or the sender's address.
    1. Under Step 1: Select exception(s) (if necessary), place a check in the except with specific words in the recipient's address check box.
    2. Under Step 2: Edit the rule description (click an underlined value), click the specific words link.
    3. In the Specify a word or phrase to search for in the recipient's address: text box, type: LISTSERV
    4. Click the Add button.
    5. Click OK.
    6. Under Step 1: Select exception(s) (if necessary), place a check in the except with specific words in the sender's address check box.
    7. Under Step 2: Edit the rule description (click an underlined value), click the specific words link.
    8. In the Specify a word or phrase to search for in the sender's address: text box, type: LISTSERV
    9. Click the Add button.
    10. Click OK.
    11. Click Next.
    12. Click Finish.
    13. Click OK.
    14. In the Rules and Alerts window, click OK.
  4. Set Outlook to check mail every 60 minutes. For instructions, refer to Configuring Outlook 2003/2007/2010 to Automatically Check Mail at Regular Intervals
  5. When you return, disable your automatic reply filter.
    2. Next to your automatic reply rule, clear the check box.
    3. Click OK.
Apr 10, 2012 | Microsoft Office Outlook 2007: Windows
cant copy tables from internet to word 2007
Open a web browser such as Windows Internet Explorer by clicking the "Start" button in the lower left-hand corner and double-clicking "Internet Explorer" in the program list.
  • 2 Display the webpage to be copied, then click the "Edit" tab at the top of the Internet Explorer screen.
  • 3 Click "Select All" to highlight the entire contents of the webpage, then click the right-hand mouse button and select "Copy" from the drop-down menu. This copies the entire webpage to a temporary memory clipboard.
  • 4 Open a blank Word document by clicking the "Start" button, choosing "All Programs," clicking "Microsoft Office" and double-clicking "Microsoft Word."
  • 5 Click the "Edit" tab at the top of the Word screen and choose "Paste Special."
  • 6 Select which paste option best suits your needs. For example, the "HTML Format" option will paste the copied webpage with all hyperlinks, images and text formatting intact. "Unformatted Text" option will paste only the text from a webpage without any of the original columns, section dividers or other formats.
  • 7 Click "OK" to copy the webpage into the Word template
  • Oct 03, 2011 | Microsoft Office Professional 2007 Full...
    I have a yahoo business email account and I am using outlook 2007 to access my emails. I would like to use the auto-reply in outlook to alert all incoming emails that I am out of the office
    Hi Cecil,
    First you'll need to create a message template.
    1. On the File menu, point to New, and then click Mail Message.
    2. On the Options tab, in the Format group, click Plain Text.
    3. In the message body, type the message that you want to send as your automated reply.
    4. In the message window, click the Microsoft Office Button za010077102.gif and then click Save As.
    5. In the Save As dialog box, in the Save as type list, click Outlook Template (*.oft).
    6. In the File name box, type a name for your message template, and then click Save.
    Once the template is finished, you'll need to set up a new rule to reply to the incoming messages.
    Do the following:
    1. On the Tools menu, click Rules and Alerts.
    2. In the Rules and Alerts dialog box, click New Rule.
    3. Under Start from a blank rule, click Check messages when they arrive, and then click Next.
    4. Under Which condition(s) do you want to check?, select the sent only to me check box and any other criteria that you want, and then click Next.
    5. When you see a dialog box informing you that this rule will be applied to every message that you receive, click Yes.
    6. Under What do you want to do with the message?, select the reply using a specific template check box.
    7. Under Step 2: Edit the rule description (click an underlined value), click a specific template.
    8. In the Select a Reply Template dialog box, in the Look In box, click User Templates in File System.
    9. Select the template that you created in the previous section, and then click Open.
    10. Click Next.
    11. Optionally, select the check boxes for any exceptions to the auto-reply rule.
    12. Click Next.
    13. Under Step 1: Specify a name for this rule, type a name for the auto-reply rule, and then click Finish.
    Hope this helps!
    Please don't forget to rate;)
    Gary
    May 18, 2011 | Computers & Internet
    Can you save a text template to be put on your texts every time
    Yes, it is actually called a signature. Go to your message settings and you should see signature option, select that and then add the text you want to be on your messages. But make sure that your signature is turned ON in your message settings. Hope this helps!
    Mar 28, 2010 | Samsung Propel A767 Cell Phone
    476 people viewed this tip
    David Payne
    David Payne
