Tip & How-To about Televison & Video
Sony TV Error Code - Six blinks.
You try to turn on you Sony TV and nothing seems to happen. Then you notice the standby/power lamp is blinking. Counting the blinks during the short versus long pause reveals that the unit is blinking 6 times, pausing for 3 seconds then blinking 6 times. This continues as long as the unit has power.
What does this mean? It means that you have a serious problem in the horizontal drive circuit. The horizontal circuit provides the high voltage (38kv or higher) to drive the electron beam to the front of the CRT and the phosphors.
This diagnostic tool is there to help you narrow down the area of the problem. For this blink sequence you need to look in the vicinity of the flyback transformer. It is the large, round or squarish, device, near the rear of the set. In Sony's it is almost always on the right rear corner of the set. You can recognize it by the large red rubber wires (four total) coming from the unit. One is unput, three are outputs and go to a focus divider block or more recently to the CRTs.
The flyback takes about 1000 volts ac and raises it to over 38 thousand volts dc. This is done by have a few turns of wire on the primary of the transformer and many turns on the secondary. This is determined at the factory and sets the level of the voltage. TVs use a pulse at 17750 khz/sec to create the stepup voltage. This is provided by circuitry which includes a switching transistor or IC.
The switching device must control a small current/high voltage but gets very hot because of the high frequency that it runs at. Many times the horizontal output transistor is blown. When replacing the HOT always replace the flyback as more than likely it is shorted or partially shorted and will just blow a new HOT immediately or within a week.
If you can use a DMM and know how to test transistors you can check this. It will be near the flyback and mounted to a large aluminum heat sink.
I have a tip at http://www.fixya.com/support/r4916941-diagnose_repair_projection_tv_high which will help walk you through it and also tell you where to get the parts at the best price.
If you do not have the experience you may want to consider just replacing the entire board. Prices have come down quite a bit and there are aftermarket repair facilities which will repair the board as good or better than new and have the same or better warranty as a new board. I have a tip at http://www.fixya.com/support/r6981868-replace_circuit_board_in_modern_tvs which will give you tips and the know how to accomplish the board swap and also the best places to get the new board.
If you have troubleshooting skills and want to try to fix the unit yourself, check the HOT, Flyback, C515, C516 and the jungle IC, IC206. For this kind of repair you will need a service manual. http://encompass.com has many posted on their site, but not everyone. http://servicemanuals.net has all service manuals and you can download most for around $16.00 USD.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Televison & Video Logo
Sony FD Trinitron WEGA..won't turn back on TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of an
Visit this site for details. All information about this type of fault [2 blinks of standby light to sony Trinitron]; are described here in detail.
"Electro-help", is the name of the site.
Search for it on Google.
May 02, 2012 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
sony wega kdf42we655 power led blinking red
If lamp light is on at tv front then replace lamp as existing lamp sounds dead/ broken.
Lamp replacement procedure would be written in user manual of tv.
And if lamp light is not on but standby light is blinking then let me know how many times it is blinking to find out problem cause as standby light blinking is an error code.
Mar 25, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Grand WEGA KF60DX100 Powers on and off then 32 blinks
The current lamp and lamp driver part numbers and prices for the KF60DX100 are as follows:
Lamp: XL2000U, $200 (USD)
Lamp driver: 1-468-510-15, $263.16
This assumes that you have the US model.
Dec 14, 2007 | Sony Grand WEGA KF60DX100 60" Rear...
1,159 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
