Tip & How-To about Bugaboo Cameleon Jogger
HOW TO FIX BUGABOO WHITE SEAT BUTTONS
To fix it yourself, you need to disassemble the buttons, which can be done with two screwdrivers one a thin slot type the other a Phillips. Here is the process: 1. On the other side of the white button unit is a screw. Remove it using a Phillips screwdriver.
2. You'll now have a black housing with a white button held in by three white tabs. 3. Free the white button from the housing by pressing inwards on each of the three tabs with the slot type screwdriver.
4. You'll now have a black base, a spring and a white button. Pay attention to how the two black parts align to each other so you re-assemble it correctly.
5. Pop the white button out of the upper black surround. Sand the circumference of the white button evenly until it slips easily in and out of the black surround. A little silicon spray is a good idea.
6. Reassemble unit and check it has full movement (see photo below).
7.
On the underside of the button unit a ramp shape should lineup with an opening in the bottom edge.
8. Fit button unit back into upper seat leg, Fit lower seat leg aligning it to the back of the button unit so the push rod in the lower seat leg pushes on to the ramp on the button unit. Note the seat button will not come out and lock until the seat is fitted back on to the chassis pushing the rod up to push the button out to the lock position. Once you have fitted the back screw in you can use a large screw driver to push down the inside of the lower leg to check the white button pops out and locks. If you have any resistance dismantle again to check alignment and the condition of the interlocking teeth of the button and the outer rings. Sand of any burrs and use a little silicon grease. Reassemble and test again.
Repeat operation to the other side if necessary. Buttons are not interchangeable so doing one side at a time avoids mixing them up.
If the tabs on the white button are broken you can buy a new button unit as a part www.babycare.nl/bugaboo-cameleon-seat-frame-push-buttons-p-2664.html
Bugaboo Cameleon Jogger Logo
Sony Remote RM-YD035 does not change channels or turn off TV
You have worn those buttons on your remote out. Those are you most used buttons. You can have you remote repaired by pros here. You can buy a new Sony RM-YD035 here. Or you can purchase the keypad repair kit here and fix it yourself.
Oct 05, 2012 | Sony Rm-yd035 Remote Control
I have a bugaboo frog stroller that the seat recline buttons are not working. They will push in, but do not pop back out. Any thoughts?
To fix it yourself, you need to disassemble the buttons, which can be done with two screwdrivers one a thin slot type the other a phillips. Here's the process: 1. Behind the white button is a screw. Remove it using a phillips screwdriver. 2. You'll now have a black housing with a white button held in by three white tabs. 3. Free the white button from the housing by pressing inwards on each of the three tabs with the slot type screwdriver. 4. You'll now have a black base, a spring and a white button. 5. Sand the circumference of the white button evenly until it slips easily in and out of the black surround. A little silicon spray is a good idea. 6.Reassemble and repeat for the other side. If the buttons are broken you can buy them as parts www.babycare.nl/bugaboo-cameleon-seat-frame-push-buttons-p-2664.html
May 16, 2011 | Bugaboo Baby Gear
Seat wont lock into position as white buttons wont pop out
We had this same problem and I just fixed it today. What is happening is either the white plastic buttons expand with time (highly unlikely) or the black plastic housings shrink with time (more likely). To fix it yourself, you need to disassemble the buttons, which can be done with two screwdrivers, and sand down the edges of the white buttons to make them slightly smaller. Here's the process: 1. Behind the white button is a screw. Remove it using a phillips screwdriver. 2. You'll now have a black housing with a white button in it, held in by three white tabs. 3. Free the white button from the housing by pressing inwards on each of the three tabs in turn. 4. You'll now have a black base, a black surround (where the button sits), a spring and a white button. 5. Sand the circumference of the white button evenly until it slips easily in and out of the black surround. 6. Reassemble and repeat for the other side. Good luck, Jesse.
Mar 05, 2011 | Bugaboo Cameleon Stroller
How do I fix one of the frame support buttons on a Bugaboo Cameleon, as the lefthand button is stuck?
Do you mean the tilt buttons? If so you need to disassemble the buttons, which can be done with two screwdrivers one a thin slot type the other a phillips. Here's the process: 1. Behind the white button is a screw. Remove it using the phillips screwdriver. 2. You'll now have a black housing with a white button held in by three white tabs. 3. Free the white button from the housing by pressing inwards on each of the three tabs with the slot type screwdriver. 4. You'll now have a black base, a spring and a white button. 5. Sand the circumference of the white button evenly until it slips easily in and out of the black surround. A little silicon spray is a good idea. 6.Reassemble and repeat for the other side.
Jan 16, 2011 | Bugaboo Cameleon Jogger
my bugaboo cameleon white buttons have stopped working??
Dec 05, 2009 | Bugaboo Cameleon Jogger
6,764 people viewed this tip
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
