Tip & How-To about Computers & Internet
How to Repair or Replace a Key for a Keyboard.
Keys sometimes pop out or are accidentally bumped and fall off the keyboard. Here's a little trick to help you put the key back on:
1. Gather all the pieces or parts of the key - normally there are four parts: the key itself, a rubber nipple, and two base hinges.
2. Gently lift the key next to the one that popped out - just remove the key and do not remove the other parts. This is going to be the "reference" key.
3. Observe the assembly of the parts and make note of how they are connected at the base.
4. Replace the base hinges first - compare it to the other key base and make sure the rubber is in the center. The two hinge parts must be connected correctly like the "reference" key. Use a magnifying glass to see the proper assembly - do not alter the connection.
5. Replace the key - align it over where it's suppose to be and sharply snap it into place. You should hear a noticeable clicking sound if all the parts are assembled properly.
6. Test the key.
7. Replace the "reference" key back on.
8. Done!
Computers & Internet Logo
How to remove keys from mk700 keyboard
Are you wanting to clean it? You can use a butter knife or a flat screw driver .to gently pry the keys off. Doe this while pc is off.. Take the knife and place it between the keys and gently lever down at and angle. The key will be a little resistant but will pop off. Sometimes a keyboard has a few keys such as the space bar the are held with little metal bar which can be annoying when placing the keys back in. When placing them back in you will hear a little snap. This just means it is in. No worries.
Jul 09, 2014 | Dell 0Y3740 Keyboard
only some letter keys work,all # keys work,Accer 5517 laptop
Kevin, it seems like the keyboard is bad on your laptop. If it has an extended warranty you should take it in for repair.
Did something spill on it recently or did it fall? Sometimes bumps or falls can cause connections to become loose and malfunction.
To gain access to your computer you can try a usb keyboard.
Jan 20, 2013 | Acer Aspire 5241 5251 5332 5334 5338 5516...
Some keys on my laptop are hard to press, you must to push a little bit harder before the letter comes up, they are not soft touch anymore. What will I do with that?
You need to clean your keyboard:
Invert your laptop so that the keyboard is inverted over a piece of clean paper: you might be surprised to see all the junk falling out of the keyboard. Briskly blow air between the keys and repeat the exercise several time.
If softdrink or food was accidentally spilt on the keyboard, you may need to very careful and gently lift out the appropriates keys and clean the mess with wet cotton bud. Putting the Press on key caps can be pretty tricky so observe how they are originally fitted.
Hope it helps. Let me know how you go.
Sep 27, 2010 | Computers & Internet
my tab and delete button are not working
take the keyboard, flip it over, bump it on something, NOT TOO HARD, maybe some garbage is in between the keys, shake it a little to see if something comes out, don't worry about keys, springs, whatever, keyboard won't fall apart :) sometimes stuff gets in.
Sep 15, 2009 | Logitech Cordless Desktop EX110 Keyboard
Keyboard problem
Cleaning your keyboard may require popping the keys off. Sometimes this may invalidate your warranty; check with the manufacturer to be certain this is something you want to do.
If your keys feel sticky or are grinding, a drop of a light machine oil, such as WD-40, placed in the center of where the key strikes the keyboard, on the hinge, or on the spring (if your key has one) should do the trick. (However, this will require removing keys from the keyboard.)
Keyboard manufacturers don’t recommend popping off keys, but it’s generally harmless if you handle the keys gently. Stick two plastic knives under opposite sides of a key and pry upward, exerting equal force on both sides. The key is guaranteed to fly off across the room, but that’s how you do the job without breaking the key or the switch. Once keys are off, they’re actually washable. Rub stains with a wet cotton swab dunked in soapy water, which does the trick for most messes. Save the alcohol for truly stubborn gunk, because it can damage the ink on the keys, and never, ever, ever use ammonia-based solvents such as Windex.
Mar 02, 2008 | Fujitsu Siemens FKB 8720 Keyboard
259 people viewed this tip
David Payne
David Payne
