Tip & How-To about Computers & Internet
Tips to Use Computer Network Cabling
Problems in computer network due to computer network cabling can be stressful for someone. follow the simple tips mentioned below to keep away from issues caused by network cables:
They come with eight wiring standards which are T568a and T568b. to keep away from any trouble it's recommended that you ought to not merge the eight wiring standards on a same network.
in case you are fixing network cabling in a brand spanking new place, it's suggested that you ought to go in for patch panels to forestall any computer network problems.
in case you need your cables to give an optimal result make positive you buy the right plugs for them.
Make positive the cables you use are not over eight hundred sixty four feet long and ought to be devoid of any joints.
Network cables ought to not be placed along the electrical cabling and also avoid suspension of network cables on ceiling.
To prevent any network issue make positive that no network cable is crooked or even turned. And also stay away from metal pins for securing cables.
A network cable consists of four crooked wires which come in different hues of brown, orange, blue and green. To steer clear of any network issue make positive that not over a quarter inch of the cable is untwisted at both the ends.
As mentioned above that a cable has four wires. usually only eight are used but still it's essential you keep all the pairs wired to uphold network requirement.
While doing network cabling for your network always use the highest quality tools. receive a lovely quality crimping gizmo for the same. basically steer clear of pliers.
In areas where radio frequency is on the higher side, try and use shielded crooked pair or STP network cable in lieu of unshielded crooked pair or UTP network cables to avert meddling.
Computers & Internet Logo
what parts are needed for installing a 102" CB
1. swr meter
2. mount. for a car.. make your own.. YOU DON"T NEED A BALL MOUNT... any mount will do.. just make sure it can handle the stress from whipping in the wind and hitting trees.. lol.....just make sure to keep away from body @ least 12" for better swr's.. DO NOT put right up against the body. unless its on top of trunk or roof.. or a tool box. if on a pickup. the stack pocket is a good distant away from the cab to work.. do not put right up agianst the bed near the glass it will give high swr's because of the roof is right there.
3. cables.
4. make sure it has a good ground. clear of any obstructions. like body panels..
Feb 04, 2011 | Cobra 25 LTD 40-Channels Base CB Radio
my intenet connection is very slow due to my router
This mentions Linksys, but it relates to all routers
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 04, 2009 | Computers & Internet
304 people viewed this tip
David Payne
David Payne
