Tip & How-To about Cell Phones
PUK Code problem - Sim Card
A PUK code (which is commonly called as PIN Unlock Code) is required if a GSM SIM card was locked after entering the wrong PIN code three times in a row. Entering a wrong PUK code ten times in a row disables the SIM card permanently. Both the PIN and the PUK codes are supplied by the operator, but only the PIN code can be changed by the user.
This problem is very common and most users think that it's related to phone or it's phone code problem, which is not true, it's only with your sim card and is for security reason related to sim card security. That particular sim card will never work on other handsets. We can't use software or hardware or other tricks or methods to unlock it, the only solution is from the Service Operator/Network Operator. Well, some service providers like Airtel has sms facilities to get the PUK code by sending a unique text message, but most providers don't have that facility.
If you keep entering random codes/unknown numbers several times (maximum ten times), your sim card will be rejected or blocked and will be unusable permanently.
Your only solution is to call the Service Provider (Network operator's customer care), ask them to give you your puk code, they'll promptly give it to you after few queries to make sure you are the right/true owner of the Sim Card. (there's no fee or charge as well, and if you call from the same network's sim card number to the customer care, you'll not spend/pay a penny, and of course few service providers may charge). You'll be given instructions on how to enter and change the PIN2 code by the Customer Care representative/s.
There's no other alternative, or no other options that you can get the code from, so don't play around, instead make a call to the customer care of the sim card network operator and get the code.
I wish you good luck.
Cell Phones Logo
what is puk unlock code
  1. PUK Code (PIN UnlocK Code) A PUK code is required if a GSM SIM card was locked after entering the wrong PIN code three times in a row. Entering a wrong PUK code ten times in a row disables the SIM card permanently.
    Electro help
Nov 06, 2014 | Cell Phones
what's a PUK code
A PUK (PIN Unlock Key) code is required to unlock SIM cards that have become locked following three successive incorrect PIN entries. If your SIM card becomes locked, you will need to get a PUK code to unlock your SIM card.If you enter the wrong PUK code 10 times in arow, your SIM card will be invalidated, and you will need to purchase a new SIM Card . The phone will display the following error: "PUK blocked call operator."
Jan 04, 2012 | Samsung Cell Phones
what is PUK CODE ?
A PIN Unlock Code (PUC) or PIN Unlock Key (PUK) is used in GSM mobile phones and some smartcards to unblock a blocked card.
A PUK code is required if a GSM SIM card was locked after entering the wrong PIN code three times in a row. Entering a wrong PUK code ten times in a row disables the SIM card permanently. Both the PIN and the PUK codes are supplied by the operator, but only the PIN code can be changed by the user.
Mar 22, 2011 | Cell Phones
what is puk code?
A PUK (PIN Unlock Key) code is required to unlock SIM cards that have become locked following three successive incorrect PIN entries. If your SIM card becomes locked, you will need to get a PUK code from your service provider to unlock your SIM card.
You can obtain your phone's PUK code from your local operator by calling customer care.
Once you receive your PUK code, you will need to enter it into your phone to set a new PIN code.
Note: If you enter the wrong PUK code 10 times in a row, your SIM card will be invalidated, and you will need to purchase a new SIM Card. The phone will display the following error: "PUK blocked call operator."
Hope that's help you...
Please don't forget to rate me OK for helping you...
Thanks....
Jan 03, 2011 | Nokia 3120 Cellular Phone
YES I HAVE A CELLULARONE SIMS CARD IN A PHONE AND IT IS ASKING ME FOR THE PUK CODE
A PUK(PERSONAL UNLOCK KEY) code is required if a GSM SIM card was locked after entering the wrong PIN code three times in a row. PUK code is a SIM specific code assigned by your service provider. No way you can guess and enter it. So, when it asks for the PUK code, don’t do anything, get the PUK code from your service provider. If the PUK code is entered 10 times wrongly the SIM card gets permanently blocked.
Call to customer care using any other mobile phone which uses the same service provider. They will ask some details about you to make sure you are the owner of the SIM card. Questions might include your billing address, email ID, numbers you recently called or messaged etc. They might even ask you the number printed on the SIM card, so be prepared with all details before calling them. Once you get the PUK code, enter it into the phone and your phone will return to normal.
Jun 21, 2010 | Lands Phones
4,576 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
