Tip & How-To about Cameras
Zeikos audio tip
Do NOT expect good audio from the Zeikos Digital Camcorder. I tried and it crackles.
If anyone has a troubleshooting tip I'd be delighted to hear it.
Cameras Logo
Loudspeakers crackle
The audio output section circuit should be troubleshooted. The most possible cause is with its audio output IC itself. Check for any loose solder terminals to this section.
Jul 15, 2012 | Philips 42PFL5332D 42 in. LCD Television
Tape will not load; Error code 31:23
You may try the following troubleshooting steps:
Remove the battery of the Camcorder for one minute and re-insert the battery to check whether it works.
You may try resetting the Camcorder by pressing the RESET button located on it.
You may also check whether the issue occurs for all the tapes.
If the issue occurs with all the Tapes then it seems that internal parts of the Camcorder are malfunctioning.
Hence, the Camcorder requires service.
Jul 14, 2010 | Sony Handycam DCR-PC1000 Mini DV Digital...
PS3 hdmi Audio problem Crackling Sounds
I CHANGED THE AUDIO SETTING UNDER HDMI FROM AUTO TO MANUAL AND I REMOVED DOLBY 5.1 FROM SELECTIONS.LEFT THE OTHER 2 SELECTIONS THAT WERE ALREADY SELECTED FROM AUTO SET FOR HDMI I HAVE NOT HAD AUDIO PROBLEMS SINCE.
Nov 05, 2008 | Sony Playstation 3 (PS3) Console
powers on, audio works, no video at all
First, need to narrow down the problem. Did you perhaps change the input source? To this point, change the input source, there should be text on screen that indicates what source is selected.....do you see this? Change the volume....do you see the volume level bar on the screen?
May 12, 2007 | Toshiba 61H70 61" Rear Projection...
203 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
