Tip & How-To about Televison & Video
Sony TV Error Code - Three blink solution.
You try to turn on your Sony TV and nothing happens. Then you notice that the standby light is blinking. Counting determines that it is three blinks about a second apart followed by about a three second pause.
Your problem is that the B+ over current protection circuit has been tripped. This is a problem in the power supply circuit, check T603 and R672. A better solution may be to replace the board. Let's face it, the board is as old as the TV. Replacing some parts does not change this. Fortunately these days circuit boards are not that expensive. I would recommend replacing the defective board. The board with all the power supplies in a Sony is generally the "A" board and contains the High Voltage power supply.
Two of the best places to get the board are http://www.encompass.com or http://www.shopjimmy.com . Prices are similar but both sites are trustworthy and will allow you to return the boards if they are not the problem.
If you haven't replaced a circuit board I have a tip at http://www.fixya.com/support/r6981868-replace_circuit_board_in_modern_tvs which explains the process and should be helpful to complete the repair.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Televison & Video Logo
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
626 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
