Tip & How-To about Televison & Video
Sony TV Error Code - Two Blink Solution
You try to turn on your Sony TV and nothing happens. Then you notice that the standby light is blinking. Counting determines that it is two blinks about a second apart followed by about a three second pause.
Your problem is that the B+ over current protection circuit has been tripped. This could be a short in any of the power supply circuits.
Fortunately these days circuit boards are not that expensive. I would recommend replacing the defective board. The board with all the power supplies in a Sony is generally the "A" board and contains the High Voltage power supply.
Two of the best places to get the board are http://www.encompass.com or http://www.shopjimmy.com . Prices are similar but both sites are trustworthy and will allow you to return the boards if they are not the problem.
If you haven't replaced a circuit board I have a tip at http://www.fixya.com/support/r6981868-replace_circuit_board_in_modern_tvs which explains the process and should be helpful to complete the repair.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Televison & Video Logo
50 PLASMA TV WONT TURN ON RED LIGHT BLINKS BUT NOTHING HAPPENS
By blinking led it show there is some fault. By counting the blinking you can be able to identify which part or board is faulty.
If you wiah to get some more details about flat panel television repair and error codes then check the following link.
http://electro-medical.blogspot.com/
Jul 08, 2016 | Televison & Video
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
Jun 19, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
892 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
