Tip & How-To about Computers & Internet
PC and MAC compatibility
It goes after adage that aggregate is PC compatible, but not all casework are are compatible with the Mac OS. If you apperceive how to configure your remote access (dialer), you can accomplish any of these services work, but few action the accelerated account for Macs. If you are a Mac user, attending for a account that gives acceptable instructions on how to accoutrement your Mac for application their service.
Computers & Internet Logo
How to use telephone modem in mac ? Can you guide me through step by step to use telephone modem in macbook ?
Unfortunately dial-up modems are no longer made by Apple. However, there are still a number of dial-up modems available from third parties - Zoom and Belkin still make USB-based dialup modems, I believe, and Apple did at one point make a modem that may still be available through third-party retailers such as Amazon or Ebay.
Whichever you choose, install the software that it comes with and then follow these instructions:
  1. From the Apple menu, choose System Preferences.
  2. From the View menu, choose Network.
  3. Choose "Internal Modem" from the Show pop-up menu (or the "Configure" pop-up menu prior to Mac OS X v10.1).
    If your computer does not have a built-in modem, select your external modem.
  4. Mac OS X v10.5 or later: From the Configuration pop-up menu, choose Add Configuration.
    Mac OS X 10.4.x or earlier: Click the PPP tab.
  5. Enter your information into the relevant fields. Your username goes in the Account Name field, for example. If you want to copy this connection information to other user accounts on this computer, select "Save password".
  6. You should now be able to connect. If you need to configure DNS servers or other advanced settings, continue to the next step.
  7. Mac OS X v10.5 or later: Click the Advanced button, then click the DNS tab.
    Mac OS X v10.4 or earlier: Click the TCP/IP tab. Choose either PPP or Manually from the Configure pop-up menu, as instructed by your Internet service provider. If configuring manually, type the IP address in the matching field.
  8. Type the DNS server addresses in their field if necessary (click the "+" button first in Mac OS X v10.5 or later).
  9. Click OK.
  10. Click Apply (or Apply Now for Mac OS X v10.4 or earlier).
Jun 24, 2011 | Apple 133 MacBook Intel Core 2 Duo 24GHz...
I'm trying to scan a photo from my HP700 onto my MacBook and I have the CD that came with my printer - but still can't do it. The Mac does not recognize the disk.
try downloading scanner driver compatible with mac os here. though unlikely, it is still possible the the cd inculded with your scanner does not have mac os compatible driver.
Mar 16, 2010 | Apple MacBook PC Notebook
I have linksys wireless-G 2.4Ghz broadband router connected to a pc. My wife bought a MAC and wants to get rid of the PC. Is the router compatible with a MAC? If so how do I download the software to set it up?
Hi! Absolutely, the Router is OS independent. All you need is a computer with a properly configured Ethernet LAN adapter and a web browser to configure the Router. Any platform that supports Ethernet & TCP/IP is compatible with the router. You may need to provide additional hardware & software (i.e. Ethernet cards and/or software drivers) to ensure that all clients operate with the router.
By default of your mac computer it has already a buil-in LAN port same as your pc and it should be properly configured. just connect the cable from the mac lan port and the other end goes to your port 1 to 4 of the linksys router and it should give you an internet connection. if there is no internet access, pls check the ff:
1. Go to system preferences, network
2. It will pop up the network window
3. location set it to automatic
4. show - set it to built in ethernet
5. once you set it to built in on the lower portion it should set to tcp/ip and the ip address should show, once there is an ip address, you should get an internet connection, sabe or apply the settings
6. you are going to do the same thing if you are going to set the pc on a wireless connection.
if you have any querry pls feel to get in touch..
Aug 16, 2009 | Linksys Wireless-G Broadband Router
269 people viewed this tip
David Payne
David Payne
