Tip & How-To about Washing Machines
No spin - tip for all washers.
Hi.
If you have no spin there may be different reasons behind the problem. Before advancing to spin the timer board performs a test on drain part of the cycle, stops the drain and checks the door lock. Drain system, pressure switch and lid switch are all parts that if defective may cause no spin.
The first part to be tested is the drain system. This must be checked regardless of the fact that the pump is working. If there is blockage, residual water in the drain system or water flowing back from drain hose may cause the washer not detecting that drain is complete, and not advancing to spin.
Disconnect power and check the drain system, accessing drain filter and hose connected to the drain pump.
In most front loaders this is accessed removing the trim at the base of the front side of the appliance (under the door), and rotating the filter cap counterclockwise. The filter should be located behind the trim at the base of the washer.
Top loader usually offer access to pump either from back or from the bottom of the appliance. In some case (eg.Kenmore top load) you have to lean the machine forware to gain access to the bottom part of the unit, where the pump is located.
After opening the pump hose cover be prepared to collect a good amount of water. Keep a container at hand. Ensure that power is not connected before starting.
Also double check drain hose at the back of the appliance, and check that the elbow height is as prescribed in manual. Incorrect drain hose settings may result in syphoning, that means water is flowing back from drain hose into the washer tube. This may result in no spin.
After performing the check on the drain system test washer again. Sometimes removing eventual blockage in drain pump may fix this kind of problem.
If the pump is draining, but drain doesn't complete, and if there is no blockage in drain lines, a parts that may be causing the no-spin problem are pressure switch and door latch switch.
The door latch switch is checked by electronic control before advancing to spin. The door switch is tested running a cycle with the door switch contacts jumped. If the model has a lock motor more testing is needed. In that case the switch is tested ensuring that the lock motor impedance reads according to specifications and energizing the lock motor.
If the drain stops always at same point and cycle does not advance replace also the pressure switch. The pressure switch detects water level and determines when drain is over and when to advance to spin. This part is difficult to test in full, the part is not expensive and it is usually replaced without testing. Pressure switch is a common failure causing no spin. If drain is OK, then either pressure switch or lid switch/lock system is usually responsible.
If the above is OK , with top loaders you need to add to the list the problems related to motor and transmission. In front loaders, check problems related to motor and motor control unit. Such problems will be near to the end of the troubleshooting list. Check them before deciding to replace the electronic control.
If all the other parts are OK, what remains is the electronic control module (CCU). The CCU is rarely causing no spin. A defective electronic control module usually results in an error message being prompted, or in the machine not working at all. The part is tested in full reading volts while the machine is operating. In some case it is possible to find a faulty CCU by visually inspecting the board or by testing the module at component level.
For safety reasons some of the operations proposed in the tip are suitable only for a trained technician. Always ensure that power is turned off while inspecting and maintaining the appliance.
Good luck
Ginko.
Washing Machines Logo
water keeps clicking of after 5 sec same with draining water and drum wont sprin
Hi Robert.
If the machine fills with water and cycle starts but it does not spin and drain, then possible problems are drain hose, drain filter, pressure switch and less frequently pump.
Always disconnect power cord or trip the circuit breaker before performing maintainance operations.
If you need to contact a qualified technician, call the phone number listed on the owners manual.
To find parts give me the model number or click on the link below, select distributor and enter your model number.
Parts and diagrams
Regards.
Ginko
Dec 04, 2011 | Washing Machines
whirlpool ISQ911PW3..problem works fine until last dry cycle.....does not spin dry
Hi.
Check drain system and pressure switch. As first thing I would check the drain pump. The access is either from bottom or from the back of the appliance.
Disconnect power. Reach the pump. Get a container ready. Remove hose from pump and collect water. Remove blockage if any. Check the hose at the back of the machine. Test with the hose down in a bucket. Access pressure switch in control assembly and clean hose connected to the pressure switch or replace the pressure switch.
The article at this link offers some more description about no-spin problem troubleshooting : If you have no spin there may be different reasons behind the problem. Before advancing to spin
Regards.
Ginko.
Aug 06, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
does not want to drain the water after washing circle
Hi.
Start checking the drain hose at the back, and the hose attached to the drain pump, located at the bottom of the appliance. After that access the control panel and clean the hose attached to the pressure switch. Also check the lid is closing well. Those are the only easy fixes.
The first parts to check are door latch and drain system.
The timer performs an additional check on the door latch before advancing to spin. The door switch it is tested by jumping its contacts, or by reading impedance to check if the switch is opening and closing the circuit (you will need a multimeter).
About the drain system,
if the machine does not drain, then the cycle will not advance to spin.
The electronic control checks the input from pressure switch (which detects water level) before advancing to spin part of the cycle. If there is a drain problem, then the machine will not spin.
The first step will be accessing the drain pump.
Kenmore top loaders' washer pump is accessed from the bottom side of the appliance.
Get ready to collect the water that will come from inside the tub.
Check also the drain hose at the back. Ensure that the height of the hose elbow is respecting the specifications indicated in manual. A wrongly placed hose will result in water going in the washer drain pump and tub, causing drain problems and no spin.
If lid switch and drain lines are OK, replace the pressure switch, which is difficult to test (it is tested reading impedance with tub full and empty. Before replacing the switch, you can try cleaning it and blowing into the switch pipe. Check also motor before replacing the switch. The switch is connected to a long rubber hose and it is located in the control panel.
Below an article about the no spin problem. If the problem is coming with no drain, check drain filter, drain hose at the back. If they are OK, the pressure switch may need to be replaced or the pump may be defective.
Here the general troubleshooting for no spin: If you have no spin there may be different reasons behind the problem.
Enter full model number here (the one written on tag) to get all parts and diagrams for your washer.
Regards.
Ginko.
Mar 19, 2011 | Speed Queen AWS75NW Top Load Washer
my whirlpool ultimate care series washer does not drain and won't spin. what seems to be the problem?
Hi.
It is a drain problem. The machine timer won't advance to spin until it detects that drain is complete. For this reason the machine is also not spinning.
Check lid switch first, this is testted with a multimeter.
Ensure that the drain hose at the back is not clogged or kinked.
Access the drain pump and undo the hose attached to the pump, see if there is any blockage in there.
The pump can be fully tested by a technician energizing it directly.
If the drain system is fine check the pressure switch that detects when the drain is complete, this should not be the case.
If all the rest is OK, replace the control board.
You can find parts and diagrams for most models here.
Regards.
Nov 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
7,055 people viewed this tip
Top Washing Machines Experts
