Tip & How-To about Microsoft Windows XP Professional
How to reset the bios password using PC CMOS Cleaner.
Burn the PC CMOS Cleaner iso ..using ImageBurner or Nero
1.Start up
Insert PC CMOS Cleaner CD, Set BIOS to boot from CD/DVD-ROM.
The first page presents to user is : PC CMOS Cleaner is ready to run.
PC CMOS Cleaner will try to decrypt the encrypted password store in CMOS and list the possible results in the list box:
BIOS type : the type of the BIOS.
Possible passwords:
possible passwords store in current computer. The passwords are listed between '' .
3. Reset the BIOS to default state
If the possible passwords do not work. PC CMOS Cleaner will try to reset the BIOS to the default state.
This action will blank the BIOS password. You may also lose all your previous settings.
There are two choice for you:
Choice 1: Reset password (try to keep date and time)
This choice will try to reset the BIOS, but keep the date and time.
Choice 2: Reset bios (all setting will be set to default, password will be erased)
This choice will reset all data in BIOS to default state.
Please try the Choice1 before Choice2.
Microsoft Windows XP Professional Logo
i forgot passwords need help!!
Download "Elcomsoft System Recovery Pro", below is the link
Part 1 http://w17.easy-share.com/1702634132.html
Part 2 http://w17.easy-share.com/1702634131.html
Download both the part in a single folder and double click the part1.rar file.Extract the ISO image file using winrar.Burn the ISO Image in a CD using Nero or MagicISO or PowerISO etc.
Now, boot the system using the CD in the CD-ROm drive( set your system BIOS to boot from CD-ROM as the first Boot Device.
Wait for sometime, and run the simple wizard to recover your earlier password or to reset a new password.
That's it.
The software doesn't change anything just get you the password,so your system will be intact as before.
Jan 13, 2010 | ASUS Eee 4G Notebook
bootable dvd
Make an ISO image and burn it on a different DVD and you will be able to boot it. make sure the source is bootable.
Jan 04, 2010 | Microsoft Windows Vista Home Premium with...
how do i recover my system with back up disk
Insert the recovery CD in your CD-ROM,Set your BIOS to boot from CD-ROM,then follow the Instruction.
That's it.
Note : Restoring your system with Recovery disk will erase your entire Operating drive data.Make sure you backup your data (if you think it has  imporatnt data) before going for recovery.
You can use any Linux Live CD distribution.But if you are not familiar with Linux.Download "Hiren's Boot CD"
Here is the link
http://www.hirensbootcd.net/
Just clikc the download button and extract the file using Winzip or Winrar.
Burn the ISO files with Nero or MagicISO or PowerISO in a CD.
Boot the system using that CD (set the First Boot Device as CD-DVd ROM in BIOS).
Select "Start Mini Windows XP"
then copy all the important files to another media.
That's it.
Jan 03, 2010 | Acer Aspire 5050-3242 Notebook
forgot system password
There are a lot of Windows password revealers and crackers available, but I’ve found that Windows Password Recovery Tool is the most effective.:
it not only supports XP, 2000, and NT, I have personally tested it with Vista Home Premium and Ultimate. It works perfectly to reset any local user account to a blank password
You can use the ISO to burn a boot CD. Follow these instructions:
1. Download ISO file from http://www.windowspasswordsrecovery.com Windows Password Recovery Tool
2. Burn to a CD using a CD burning tool such as Nero or Roxio or MagicISO
3. Insert CD into drive and reboot.
4. You may have to select an option in the BIOS to get the computer to boot from the CD.
Booting up and clearing a password takes a minute or two works like a charm.
Mar 19, 2009 | Toshiba Satellite M65-S809 Notebook
BIOS 1004 cpu not support
I got it :-)
Damn Asus , it was a hard session ;-)
1. Make an ISO from your original Asus CD denn insert (with isobuster or something) the Bios Firmware 1004 in the main Dir name the file M2N-MX.ROM
2.Burn a Second disc with the 0804 Bios ROM also rename the 0804 Rom to M2N-MX.ROM
3. Go to EZ FLASH with ALT + F2 and then insert the 1004 CD wait till Erasing is ready Then Turn OFF your PC :-) so you crashed the bios thats what you need to run the embeded CrashFRee Tool
4 After you turn your PC on insert the 0804 CD then it flashes the this Rom and we are Happy :-)
mfg Eddi Hope this helps someone
Apr 16, 2008 | ASUS M2N-MX Motherboard
1,759 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
