Tip & How-To about Cell Phones
NOKIA MOBILE CODES
3370# :- Your Nokia cell phone uses the best sound quality but talk time is reduced my approx 5%.
#3370# :- Deactivate Enhanced Full Rate Codec.
*#4720# :- Your phone uses a lower quality sound but you should gain approx 30% more Talk Time.
*#4720# :- You can deactivate the Half Rate Codec.
*#0000# :- Displays your mobile software version, Software Release Date, Compression Type.
*#2640# :- Displays phone security code in use.
*#67705646# :- This will clear operator logo.
*#2820# :- Bluetooth device address.
*#06# :- International Mobile Equipment Identity [ IMEI Number ].
#pw+1234567890+1# :- Provider Lock Status.
#pw+1234567890+2# :- Network Lock Status.
#pw+1234567890+3# :- Country Lock Status.
>NOKIA WALLET CODE
If you forgotten the wallet code, enter the following string as a telephone number:
*#7370925538#
This will allow you to delete the existing wallet and create a new wallet code. You will be prompted for the phone's lock code to proceed [ Normally 12345, unless you've change it ].
Note: This will also delete the existing data in your wallet
Cell Phones Logo
nokia restore code lose
* *3370# This Nokia code activates Enhanced Full Rate Codec (EFR) - Your Nokia cell phone uses the best sound quality but talk time is reduced my approx. 5%
* #3370# Deactivate Enhanced Full Rate Codec (EFR) .
* *#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type
* 12345 This is the default security code .
* *#06# For checking the International Mobile Equipment Identity (IMEI Number) . This can be used with almost every Mobile Phone i.e Samsung, SE, LG etc.
* *#4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time.
* *#4720# With this Nokia code you can deactivate the Half Rate Codec.
* *#9999# Phones software version if *#0000# does not work.
* #pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
* #pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols) .
* #pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
* #pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols) .
* *#147# This lets you know who called you last (Only vodofone).
* *#1471# Last call (Only vodofone) .
* *#21# This phone code allows you to check the number that "All Calls" are diverted to.
* *#2640# Displays phone security code in use .
* *#30# Lets you see the private number.
* *#43# Allows you to check the "Call Waiting" status of your cell phone.
* *#61# Allows you to check the number that "On No Reply" calls are diverted to .
* *#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to .
* *#67# Allows you to check the number that "On Busy Calls" are diverted to
* *#67705646# Phone code that removes operator logo on 3310 & 3330
* *#73# Reset phone timers and game scores.
* *#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible .
* *#7760# Manufactures code.
* *#7780# Restore factory settings. With Some Models *#7370#
* *#8110# Software version for the nokia 8110.
* *#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again.
* *#94870345123456789# Deactivate the PWM-Mem.
* **21*number# Turn on "All Calls" diverting to the phone number entered.
* **61*number# Turn on "No Reply" diverting to the phone number entered .
* **67*number# Turn on "On Busy" diverting to the phone number entered .
* press and hold # Lets you switch between lines.
Jul 22, 2012 | Nokia Classic 2700 Cell Phone
my incoming sound is extremely low . i cant hear it until i turned up the speaker . pls help me
hi i strongly recommend to go to ur nokia service provider and tell him to repair the Mic of the phone and any additional service if ur phone needs it because trying n ur own may result in some breakdown or may cause any mis-fault in the Mic so an experienced person is needed to handle the internal problems of ur mobile with care so do visit ur nokia service provider for repair and thanx for visiting fixya was this useful to u if yes pls do ate my solution.
with warm regards - bonefirediv.
Apr 18, 2011 | Nokia N73 Cellular Phone
294 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
