Tip & How-To about Cooktops
KithenAid Gas Cooktop Igniter Clicking after cleaning.
I had this problem and the solution is quite simple. Remove the control knobs and shoot a good squirt of WD-40 directly down the center of the exposed control shaft. The WD-40 will penetrate the switch located at the base of the shaft and displace the water from inside the switch, which is causing the intermittant operation or clicking of the ignition. I actually disassembled my cook top to learn this fix, but don't take yours apart it's waaay too much trouble.
Cooktops Logo
What is the problem with one knob on cooktop? How can l fix it myself?
pull knob off and wd 40 the post that holds the knob
Jul 12, 2015 | Cooktops
broken knob
Turn off the power to the appliance. Squirt WD40 liberally all round the knob, trying to get it in behind it. Wiggle the knob and press it down and up if possible to let the WD40 oil work in to the dirty or stuck joints. Leave for a few hours and wiggle it again to see if its loosened up.
Dec 15, 2013 | KitchenAid 30 in. KECC506R Electric...
The circuit breaker for out kitchenaid glass
Water probably did get into the switch(es). The best bet for a fast fix is to pull the knobs off and use an air can (like for blowing dust out electronics) to blow down into the holes. This will dry out any water in there and should allow you to use it again. To be extra sure, blow out the switches and leave the knobs off over night. In the morning the knobs can be replaced and the cook top should be good to use. Hope this helps!
Dec 11, 2009 | KitchenAid 30 in. Architect KECC507KSS...
electric range starter wont quit clicking
why u shut of the breaker,unplug the unit to stop the clicking, or clean the bottom of knobs control,remove the knob then clean by ising vaccium
Jul 01, 2009 | Cooktops
Miele KM 320 G gas cooktop ignitor
I had a similar problem and discovered that the control knob had fried itself, most likely due to liquid penetration down the shaft of the control knob and into the control knob electronics. Inside is a printed circuit board with resistor, diode and a rheostat. The surface of the board was charred beyond repair.
To trouble shoot the problem, open the cook top and hook the burner in question to one of the known good control knobs. If it ignites, then it is the control knob electronics. If it doesn’t, then there is something wrong with the igniter.
Note: The 2-zone Wok Burner had a different control knob that the other burners.
To open the cook top, do NOT loosen any of the Phillips screws on the sides. Here are the instructions from the user manual:
Disassembly
Shut off gas supply, disconnect the manifold pipe, disconnect the electrical power. Remove pan supports, burner heads and burner rings. Remove control knobs.
In the event that the hob is built in, undo the bracket clamps underneath the work surface. Lift the hob on to the work surface. Unscrew the venturis on the high-speed and super high-speed burners using a 20 mm wrench. Lift and remove the burner rings and burner base plates. Disconnect the wires from the ignition plugs. Keep the wire from dropping into the undertray by inserting it in one of the slots in the burner supports.
Remove the three screws securing the dual ring wok burner. Remove the wok burner base plate. Lift the ceramic tray from the hob.
Note: Each regulator shaft is equipped with a black ring. This ring may cling to the rubber seal in the ceramic tray. Check and remove the rings from the rubber seals.
To order parts, call 1-800-245-8215, 8:30 AM to 5:00 PM EST
Mar 04, 2009 | Miele 35 in. KM326G Gas Cooktop
944 people viewed this tip
Top Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Cooktop Expert? Answer questions, earn points and help others
