Tip & How-To about Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360)
Wireless Access Point Placement
Place your wireless access point in the average of you location. Almost all wireless access points appear with omni-directional antennas, which afford a doughnut arrangement signal in all directions. If you abode your wireless access points abreast a bank again bisected of your signal is activity out the door.
Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360) Logo
I am trying to hook up a omni antenna to a wrt54g is it possible in a motel setting
Hi there If u have a linksys wrt54g router. the omni antena will not give u the maximum wireless signal if u are going to set it on a motel, u need to setup a wireless access point in order to broadcast the signal or to repeat the signal u need a wireless access point and the model # is WAP54G..
here is the link just incase u want to know more about on how to set up a wireless access point
1. How do I configure an access point as a wireless bridge?
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4194
2. How do I configure an access point as a wireless repeater?
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4200
3. How do I configure an access point as an access point client?
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4202
4. How will I know if an Access Point is configured as an Access Point?
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4165..
check this out and i hope this will solve ur concern..
Apr 04, 2009 | Linksys Wireless-G WRT54G Router
Wireless Antenna for 1000'
you want to place, Access point in your two different location. like motoral product OR cisco .
May 13, 2008 | OTC AVCW- 115G- 80 802.11G OUTDOOR ACCESS...
Compatibility with Sitecom wl 031
This 10dBi omni directional antenna enables you to very easily extend the range of your wireless network. By linking the Omni Antenna to your wireless router, you gain the benefits of an optimum wireless signal while minimising the number of ‘dead spots’ (points in your home where the signal is either weak or lost).
However it does not fit the following types of routers,modems and accespoints:
WL-143
WL-122v2
WL-114/WL-517
WL-114v2
WL-108/WL109
WL-111
WL-106
WL-025
WL-018v2
These antenne's will also fit other brands of wireless products that use an SMA connector
Jan 29, 2008 | NetGear WGR614 Wireless Router
how to improve on Wireless Range
You can use repeater with your router to increase wireless router signal strength.
Feb 19, 2006 | NetGear RP114 (RP114CN) Router
Wireless and Antenna Terms Wireless routers, access points, and adapters send and receive radio wave signals through antennas. The antenna is hidden inside adapters, but on routers and access points there's a visible antenna. Radio waves can be focussed like a lightbulb. And like a light, some materials reduce or stop radio waves. While light focused from several lights is brighter and makes it easier to see, several antennas in the same area cause interference ? the radio signals will be muddy and confused. Your goals in optimizing power are: * Avoid obstacles. * Avoid interference. * Increase signal strength. Power affects how far an antenna radiates. * Use the equipment in places it's most powerful and most sensitive. Antennas don't radiate equally in every direction. Just as the base of a lightbulb blocks light, and just as a light can be focussed by a reflector, so an antenna signal may be blocked and focused. Since people cannot see radio waves, you'll rely on testing and trial-and-error to get an idea of where antennas "shine" most brightly. An adapter's antenna is important, but the most powerful and sensitive antennas are on routers, access points, and detachable external antennas. The focus of an antenna is either omni-directional antenna or directional. "Omnis" are used in most home products, they radiate horizontally all around, but are weaker upward or downward. When visible, these antennas are usually a rod a few inches long. A directional antenna radiates strongly in a limited direction. It is a flat panel or a dish. These are used for point-to-point transmissions (where two antennas are focused directly at each another). These need a line of sight between them, and preferably a large open space around the main beam. When you are near antennas you'll still get a signal, even if you are out of the direction of its strongest signals. But when further away, you have to be in the direction the beam is the most powerful and unobstructed to receive it. One final concept before you go to the above links is interference. Interference is a signal ? one you don't want ? at the same frequency as the one you're using. Interference comes from devices such as microwave ovens, cell phones, 2.4 GHz cordless phones, and copy machines. Interference is also caused when your own wireless signals are bounced off reflecting objects. Objects may partly or completely absorb signals, reflect them, bend them, or let them pass right through. Metal and water (including the water in people!) absorb or reflect signals. Air, wood, and glass tend to let signals pass with weakening. And when outdoors, plants and the weather may cause interference.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
980 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
