Tip & How-To about Heating & Cooling
E-3 error code
E-3 means indoor fan motor mechanism locked. Replace bearings or motor.
Heating & Cooling Logo
when i turn the conditioner on, the heat button flashes then turns off
As no error code mentioned, please check the following.
1. Indoor fan motor mechanism locked. Rotate manually, hard to rotate, replace bearing or motor.
2. If blower motor is o.k, check indoor coil sensor for continuity. If defective replace it.
Hope, helpful..
Jan 27, 2011 | LG LS-K2430HL Heat Cool Mini Split Air...
lg art cool beeps but doesnt start
Indoor fan motor mechanism locked. Or indoor coil sensor defective. Rotate manually f.m. If easy to rotate, replace sensor. If not, replace bearings or motor.
Jan 13, 2011 | LG Art Cool LA181CNW Split System Air...
The system is not working at all and don't have any troubleshooting manuals or maintenance guides to solve the problem but i am sure from that I have a problem at the indoor thermostat but i had changed it but with out any results
Check indoor fan motor mechanism may be locked. Rotate manually. If rotates, replace fan capacitor. If hard to rotate, replace bearings or motor itself. Hope helpful.
Jan 10, 2011 | Heating & Cooling
294 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
