Tip & How-To about Heating & Cooling
E-2 error code
E-2 refers indoor coil sensor defective. Replace it.
Heating & Cooling Logo
error code E1 and E2
E1 error - Indoor room temp sensor defective. Replace it.
E2 error - Indoor coil sensor open. Replace it.
Hope helps.
May 03, 2011 | Sunbeam SCA102RPC1 Portable Air...
what is the meaning of fault code. error 02. abnormal on my hitachi remote control for cooling unit rpc 5aq5-p
Indoor/outdoor safety device activated. If your unit stops within 5 seconds, indoor coil sensor defective or short of gas/leak. If your indoor works and but out door unit works for just 5minutes and stops means outdoor coil sensor defective or short of gas or leak. find by amps. If less amps than mentioned, is gas leak/short of gas.
Jan 27, 2011 | Heating & Cooling
lg art cool beeps but doesnt start
Indoor fan motor mechanism locked. Or indoor coil sensor defective. Rotate manually f.m. If easy to rotate, replace sensor. If not, replace bearings or motor.
Jan 13, 2011 | LG Art Cool LA181CNW Split System Air...
e2 york 5,5kvv air conditores
E-2 refers indoor coil temp sensor. May be defective replace it.
Dec 20, 2010 | Heating & Cooling
298 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
