Tip & How-To about Heating & Cooling
E-1 error code refers indoor room air sensor open or short. Replace it.
Heating & Cooling Logo
error code E1 and E2
E1 error - Indoor room temp sensor defective. Replace it.
E2 error - Indoor coil sensor open. Replace it.
Hope helps.
May 03, 2011 | Sunbeam SCA102RPC1 Portable Air...
Greeting, I have problem with SAMSUNG air condicioner inverter. The display shows me an error E1 A1 and does not include the external unit, please help what is the problem.
E-1 Room sensor and A1 Indoor PCB fault. Please you replace first,indoor sensor and reset.Sometimes indoor pcb shows fault code due to sensor short. After replacing sensor it will show only A! or sometimes no error. If it shows A1, you have to repair/replace PCB. Helpful?
Jan 24, 2011 | Samsung AW1203B Air Conditioner
HI I ahve a MSH-07NV airconditioner. It has had this problem before. I called a repair man and he said it was operator error. It turns on remotely then the fan stops and it goes down to 1 light that flicks on and off. I cant then get it to cool. thanks
As you don't mention the error code. There are 2 reasons for your unit as hereunder.
Check your indoor room temp sensor and coil sensor
Indoor unit return air sensor fault. Disconnect sensor from PCB and measure resistance. 8 kOhm at 30C and 13 kOhm at 20C if not replace sensor.
Indoor Pipe Sensor or Outdoor Sensor Assy fault, Open or Short. Disconnect from PCB and measure resistance. Air sensor = 10 kOhm at 25C, Pipe sensor = 5
kOhm at 25C. If not replace sensor.
Jan 07, 2011 | Mitsubishi Heating & Cooling
I have an Error code E1
E-1, Indoor room temp sensor open or short circuit. Replace it.
Sep 01, 2010 | Fedders AER12E7A Air Conditioner
327 people viewed this tip
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
