Tip & How-To about Heating & Cooling
Temperature in display changes rapidly. No cool
After completing service ensure that indoor room sensor and coil sensor placed in it's position.If misplaced temp reduces rapidly and again restarts to increase.
Room sensor placed in middle of left corner of indoor coil. Indoor coil sensor placed into copper tube brazed with indoor coil bend.
Heating & Cooling Logo
the heat sistem is not working well is working but 30% of eficency than it was working beafore.It hear like water on it ..help im frezzing
Air conditioning real definition is not giving cool but removing heat from the room. In same way for heating, it's not heating, removing cool from the room. When your indoor coil, air filter and blower wheel are full of dust, you won't get even 30% of cool or heat depend on your selection.
Simple solution for your problem is clean indoor unit completely. Check all sensor is working well. In heat mode keep temp minimum +3 degree than room temp. thanks and helpful.
Jan 30, 2011 | LG LS-L1210CL Mini Split Air Conditioner
My a/c temp rapidly going down and coming up. No coling
Check room temp sensor. May be misplaced. Place it in right position. O.K. Helpful?
Jan 20, 2011 | Samsung Heating & Cooling
outdoor heatpump unit,twx736a100a2, coils freeze over solid,replaced outdoor thermastat, checked freon and replaced a relay switch at a cost of $500/for 2 service call-outs.It worked fine whole month of a very cold dec.We had 2 days of 50' weather and now its back down in low 30's and coil froze solid again! should i call another tech.?whats next? reversing valve? control board?,thanks..going broke in ohio
Coils freezing due to dust blocked coils and or air filter or short of gas. Service your unit completely.Please do not change any spare/s without knowing exact problem. Please follow the steps given below.
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks. To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 04, 2011 | Heating & Cooling
242 people viewed this tip
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
