Tip & How-To about Heating & Cooling
How to get proper cool?
Make sure your unit serviced periodically. Keep mode in "Cool" and Set temp 23 C degree.Avoid frequently opening of the door. Screening to the windows will help to get quick cooling.And indoor to out door copper pipelines must be insulated well.
Heating & Cooling Logo
I need help on how to activate heating mode in my 7wa4501q whirlpool 6th sense minisplit pleasee
Symbolsin remote: To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
Jan 13, 2011 | Heating & Cooling
DONT KNOW EXACTLY WHAT IS WRONG. OUR POWER BILL LAST YEAR WAS 211.00 AND KNOW WITH THISE BILL IS 678.00. IT IS H EATING AN 18X23 ROOM. THE SETTING FOR TEMP. IS ON 72 DEGREES. THIS THING HAS RUN OUR BILL UP 400.00 AND THE REPAIR PEOPLE SSAY THAT THEY CANT GET HERE FOR ANOTHER 2 1/2 WEEKS. CANT AFFORD THIS BILL MUCH LESS ANOTHER MONTHES BILL LIKE THIS AGIAN. PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ANGIEW BEAM CONTACT 864-293-5371
Simple way to pay less bill with big comfort.
Tips for it: To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat" Clean indoor and out door periodically ( Once in 4 months) Clean Air filter every fortnightly. Avoid frequent opening of the door where it's air conditioned. Avoid keep closing the doors even a/c is switch off. It helps to cool the room next times in short minutes. Use proper breaker, wiring for your air conditioner plug points. Make sure your elect meter is working properly.Check your Elect meter with 1000watts bulb for one hour. It should consume one unit only. Hope, it's helpful.
Jan 08, 2011 | Heating & Cooling
I have a brand new york inverter air conditioner that does not want to cool!
Now symbols:
4. Sun- Heat
5. A or AU- Auto mode. First, check your compressor is working?
Dec 29, 2010 | Heating & Cooling
i have got 4 independent sanyo air conditioners in my home.none of them is wiorking in the "heat" mode or "cool" mode.only the fan is working. what problem can cause this situation?
Please check power in your room. Its no logic that all the units are having same problem at a time. May be common problem that is power.
To get proper cool, keep cool mode,and also temp setting 23 degree.
To getproper heat, keep your temp setting at 30+ degree and also mode in "heat"position. I
Dec 15, 2010 | Sanyo STW0923H2 Air Conditioner Heat Pump
253 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
