Tip & How-To about Nokia N95 Cellular Phone
How to disassemble a nokia n95
First remove the battery cover, battery and memory card. Move the slider down and remove the two screws you see.
Now move the slider up and remove the two screws at the top of the phone.
Run your fingernail along the edge of the join of the front cover to unclip it.
You should now have the front cover removed. The keypad should be loose as well.
Flip the keypad part back to access the ribbon which connects the LCD to the phone.
To remove the ribbon, flip back the metal hinge and then simply pull the screen back and the ribbon will be released.
Pull the LCD in the direction like you are sliding the screen up.
You can now replace the screen.
Reverse the whole procedure for reassembly.
Nokia N95 Cellular Phone Logo
fix memory error message on camera
Hi there! Make sure the SD card is not locked. There is a tiny slider on the side. If is in the "down" position, the card cannot have new files saved to it. Move the slide to the "up" position, then reinsert the card.
If the slider is very loose, it's possible that inserting it into the camera slides it down, essentially making it useless. I have one like that. You could try a touch of superglue to make the slider harder to move, but I have never tried this and you would need to be very careful not to use too much, and to make sure it's entirely dry before putting it in your camera. Perhaps try a different memory card?
Nov 04, 2014 | DXG 518 5 Megapixel Compact Camera -...
camera is somehow "card locked"
The SD memory card should be located where the rechargeable battery is, remove battery cover, should be a small tab holding the memory card in place, move it so the card pops up, remove it and look along the one edge for a switch, slide it towards the contacts to unlock the card. The switch that is furthest from the contacts is in the locked position. Now if you find the card is in the unlock position, slide it back and forth to reset, failing that replace the memory card. Sometimes the slider switch becomes defective locking out the card.
Aug 15, 2011 | Cameras
hello sir i haw n95 no light in disply
If you are not having light on your nokia n95, then it means the florescent tube of your is bad, the solution is for you to replace the screen of the phone. To replace the screen of the phone, follow the steps below:
  1. First remove the battery cover, battery and memory card. Move the slider down and remove the two screws you see.
  2. Now move the slider up and remove the two screws at the top of the phone,
  3. Run your fingernail along the edge of the join of the front cover to unclip it.
  4. You should now have the front cover removed. The keypad should be loose as well.
  5. Flip the keypad part back to access the ribbon which connects the LCD to the phone.
  6. To remove the ribbon, flip back the metal hinge and then simply pull the screen back and the ribbon will be released.
  7. Pull the LCD in the direction like you are sliding the screen up.
  8. Your phone should look like below and you can replace the LCD.
  9. Reverse the whole procedure for reassembly.
If you are not familiar with such technical activity, i will suggest you ask a friend who is familiar with it to assist you in carrying out the job.
Hope this information helped.
Jan 09, 2011 | Cell Phones
lcd screen disconnected?
to get to the screen of your phone, follow the process below:
Pull the LCD in the direction shown.
Take care
Oct 12, 2010 | Nokia N95 Cellular Phone
memory card not allow to write
Hello Mubarak_smk,
Its a very easy one to fix... if you look at the memory card, you will see a little notch or a plastic catch (depends on the card) and all you have to do is to move it.
So if the notch/catch is UP at the top... just move it DOWN...or if its DOWN move it UP.
Its that easy to do.
The memory card is a bit like an old floppy disk...if you remember a floppy, it had a hole on its top right side with a slider under it. You moved the slider to close the hole if you wanted to write to the disk and you opened the hole if you did not want to be able to write to it.... its the same idea for memory cards.
Hope that helps you, so please leave a rating so I know if it has.
Good luck
Dec 30, 2008 | Nokia 6288 Cellular Phone
2,453 people viewed this tip
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
