Tip & How-To about Office Equipment & Supplies
How to setup an all-in-one printer to scan to a computer.
You purchased an all-in-one system and hooked it up as a printer but now you want to be able to scan documents into your computer and save them to disk. How do you do this?
If you already have the unit hooked up to print you probably loaded the software off the disk which came with the unit. In many cases though you do not need to load the software as most units are plug and play. You just plug them in and the software is already in the operating system. The catch is that only the software for printing is available from the operating system.
There are two ways to load the drivers for the scanning process. One is from the supplied disk and the other is from the manufacturers driver download site on the internet. The advantage of downloading from the site is you will get the most up to date drivers and possible prloblems should be solved making for less problems for you. I will describe both options starting with downloading from a CD.
If you did not load the software from the disk yet, open the CD drive on your computer and load the disc which came with the printer.
It should start automatically, but if it does not, click on "My computer" if the icon is on your desktop, or click on start which will open a window containing "My computer".
Clicking on "my computer" will open a new window which should show the various drives (C, D, DVD-CD, etc). You need to click on the icon which shows the driver disc for the printer.
It will more than likely refer to the printer by model number. Once launched the software should be automatic and install all the necessary software drivers to run the printer to include scanning to your computer. Follow the on screen instructions and answer any questions. You may be asked where you want to store it, always choose the "C" drive.
When the software is done loading you may or may not have to reboot your computer. I always recommend rebooting, whether told to or not, to ensure that the software is accessable to the operating system.
Once the computer is rebooted you should see an Icon to launch the printer, if you do not see it, click on start. Next you will see "all programs" at the bottom of the window. Click or mouse over this. A new window will open which will show all the software on the computer. All the programs will be listed alphabetically. Find "HP 1350" and mouse over it. Find the main program (usually the name of the printer) and "RIGHT CLICK" on it.
This opens a window which gives you selections, one of which is, "create a desktop icon". Click on that and close all windows. You now should have an icon on the desktop which will link you to the software.
Click on the icon. The software will boot up and you should see a selection for "scan a document to the computer" or something similar.
Click on that choice and the rest should be automatic. Follow the on-screen instructions and you should be able to scan and save to disk anything you would like.
To install the driver from the internet log on and Google the manufacturers website. There should be a tab for support. Open this and click on driver/software downloads or perhaps just downloads. This should open another window where you enter your model number and possibly other information.
Once you are at the download page choose the driver for your operating system (XP, Vista, 7) and the number of bits (32 or 64). Sometimes this is automatic. Proceed with the download by hitting the download button. This will open a window asking if you want to run or save the program. Run the program. It should be automatic from this point but if not just follow the instructions.
When the download completes you may have to reboot. If not reboot anyway. You should see a message that new programs were installed. Now you are at the same point as above when loading from disk after the reboot and can follow the instructions above to finish the process.
Thanks for using FixYa and the great rating.
hardrocko
lost the directions for the printer directions need to know what button is for scanning pictures,
Follow these steps on how to scan from the Lexmark X2670 printer using the operator panel. 1. Open the top cover, and then load an original document facedown on the scanner glass.
2. Close the top cover to avoid dark edges on the scanned image. 3. Make sure that the printer is connected to a computer, and that both the printer and the computer are on. 4. From the printer control panel, press printmastert_51.jpg 5. If you are using a Macintosh operating system, click on the document or image preview and drag to select the part that you want to scan, and then click Scan from the Scan dialog on the computer screen. 6. If you want to save the scanned image, then from the software application, click File > Save As. 7. Enter the file name, format, and location where you want the scanned image saved. 8. Click Save.
Source: Lexmark X2600 Series User's Guide
May 11, 2011 | Lexmark X2670 All-In-One Printer
how can i scan a photo?
You can scan photos by
1 Open the top cover, and then load an original document facedown on the scanner glass.
2 Close the top cover to avoid dark edges on the scanned image.
3 Make sure that the printer is connected to a computer, and that both the printer and the computer are on.
4 From the printer control panel, press "scan" button.
5 If you are using a Macintosh operating system, click on the document or image preview and drag to select the
6 If you want to save the scanned image, then from the software application, click File Save As.
7 Enter the file name, format, and location where you want the scanned image saved.
8 Click Save.
done..
May 23, 2010 | Lexmark X2670 All-In-One Printer
canon mx320 does not scan
make sure that scan driver is completely installed in your computer.
To scan a documents in jpeg format, use the scanner icon in the control panel of your system. Insert your document in scanner bed then double click the scanners & cameras icon in the Control Panel.
To scan a documents and save in pdf format. just press the Scan button in the printer and save the documents in your computer once the scan window appear.
Oct 20, 2009 | Canon PIXMA MX310 All-In-One Printer
scanner will not work have just purchased the printer and have now got the print working but cannot get scanner working ?
scanning anything will ask for a place to save the document install kodak home center from cd or from net- www.kodak.com/go/downloads connect ur printer and computer with usb 2.0 open home center on computer
and try to scan a document by placing on scanner glass on the printer will be able to scan if not, call kodak 1800 419 1909 for further directions
Jul 08, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Cant figure out how to scan something
You can start scanning a document two dfferent ways--from the printer or from your computer. With either method, the first thing you need to do is place whatever you want to scan face down on the glass of the printer. Close the top cover.
If you want to do everything from the printer, press the button with the diamond on it. "Save Photo" should appear on your computer. You can then choose a name for the file and a location where you want to save it.
To proceed from the computer instead, you can start the Lexmark Imaging Studio. Click "Scan," select the Document option, and then click "Start."
That should get you started!
Jan 19, 2009 | Lexmark X2500 All-In-One Printer
788 people viewed this tip
k24674
jasbo
jasbo
