Tip & How-To about Computers & Internet
Troubleshooting Laptop Display Failures - The Video Cable
Symptom
When I move my notebook's screen it starts flickering.
Diagnosis & Solution
This can be an indicator that the wire bundle running through the LCD screen hinge has been compromised. Some wire has frayed apart and is making intermittent contact with itself or the lid movement is causing the wire bundle to pull on one of the video connectors. In order to fix this problem, you will need to remove the notebook's front hinge cover & check the bundle of wires connecting the motherboard to the LCD screen. If this bundle of wires is damaged, then you will have to get it replaced. To find out if there is a break in the wires, you need to remove the video cable, and perform a continuity test with a multimeter.
Another possibility is that the video cable could have become slightly unplugged either on the motherboard side, or on the inverter board side. If plugging in the connector on the motherboard side doesn't cure the problem, check the end of the video cable connected to the inverter board. The inverter board is usually located behind the display bezel of the display panel assembly, or beneath the notebook's front hinge cover.
Please Vote for this Tip if you found it helpful.
M. Omran
Computers & Internet Logo
My screen keeps going dark although I can see there are images on the screen . I have to move the lid back and forth until it lights up.
This indicates that the wire bundle running through the hinge has been compromised. Some wire has frayed apart and is making intermittent contact with itself or the lid movement is causing the wire bundle to pull on one of the video connectors.
In order to fix this problem, you will need to remove the laptop's front hinge cover & check the bundle of wires connecting the motherboard to the LCD screen. If this bundle of wires is damaged, then you will have to get it replaced.
Jan 06, 2011 | Computers & Internet
My laptop display becomes unusable when moving the display. There is only one angle that the display will work
Dec 18, 2010 | HP G60-235DX Notebook
screen goes very dark when tilted all the way back; comes on when tilted forward. Blinks off and on at the halfway point. Can this be resolved? Out of warranty.
Dec 16, 2010 | Acer Aspire One D150-1587 Netbook
picture disappears then returns when you touch the screen
Nov 28, 2010 | Toshiba Satellite Pro L300 Notebook
Have a HP Pavilion dv4-1114nr Entertainment Notebook PC that has flicker problem. Have to move the screen back and forward to find the right position so the screen will remain on. This began when the laptop backpack fell off the back seat in the car on to the floor board.
Nov 26, 2010 | HP Pavilion dv4000 Notebook
1,211 people viewed this tip
David Payne
David Payne
