Tip & How-To about Exercise & Fitness
Tips For Your Heart Rate Monitor
First, you want to adjust the fit of the chest strap.
Moistening give a more comfortable fit by reducing friction and will also help create a better connection between your skin and the receiver. It can also increase the lifespan of your belt.
When properly looked after, your heart rate monitor watch should far outlive the chest strap. More often than not any problems you find with the watch can be traced to the chest strap or the batteryIn terms of conservation, the most important thing you can do is ensure that your watch is no longer monitoring after you return from your run.
This should be easily achievable through the interface on the watch. Separating the watch from the monitor component by a significant distance will ensure that no unwanted connections continue after use.
Where possible, make sure to remove the electrical component before rinsing the strap with some running tap water. If the watch and electrical component are particularly dirty, you can use a damp cloth to wipe them down, before putting everything aside to dry. Be sure not to leave the chest strap in the sun as this can cause the material to deform, making it itchy and uncomfortable to wear.
Exercise & Fitness Logo
Sometimes, my watch gives me crazy readings such as 221 bpm at rest for my heart beat when I use the chest strap transmitter. What causes that and how can I prevent it? Could it be my WiFi internet network that interfere with the chest strap signal? Thanks.
Make sure your chest strap is a good fit so it doesn't move, not too slack. Also you need to wet the sensors so that you get a good connection. On the Garmin ones they recommend using an electrode gel but that costs money and I find spit/saliva works just as well.
Jul 25, 2011 | Sport & Outdoor - Others
need to remove the cover from a britax eclipse si..how
Press and hold down the harness release button. With your other hand below the chest pads, pull the shoulder straps forward as far as possible. With the Eclipse Si fully reclined, open the seat-belt guard at the back of the shell. Pull the yoke out from behind the seat and unhook both shoulder straps. Pull the cover from the top of the seat so that you can see the slots in the seat shell. Pull each shoulder strap and chest pad strap forward and towards the centre of the shell, easing the metal tab and straps through the slot. Then thread them through to the front of the cover. Unfasten the buckle and remove the comfort pad. Gently pull the cover off the seat, easing the shoulder straps, chest pads, harness buckle and adjuster strap through the slots in the cover.
By Geraldine Thorne
Feb 24, 2011 | Britax Eclipse Si - Chantilly
how do you wear the parents of invention ultimate ring sling?
Adjust the wide panels over both your shoulders and lower back to ensure that you are comfortable and that your child is carried safely,then bring the thinner straps around just over your chest through the loops/rings and pull tight as if tightening a belt around your waist. be sure the straps are secure and it should hold tightly with no give.
Aug 01, 2010 | Parents of Invention Ring Sling Baby...
how to choose a scuba mask
"The shape of the scuba mask and the silicone skirt on the mask must conform to the shape of your face to provide you with a comfortable fit. Ensuring the silicone skirt is a high-grade, flexible silicone can help to ensure the scuba mask conforms to the shape of your face and the long life of your scuba mask. Some people are allergic to different types of rubber, if you have an allergy to rubber, be sure to choose a silicone scuba mask because silicone is hypoallergenic. Always talk to your scuba diving gear retailer about the alternatives available to you. When trying on scuba masks you will notice the different shapes of the nose pockets. The nose pocket protects and cushions your nose, helps to keep your scuba mask from fogging during a dive and helps you to maintain equalization. Ensure the size and shape of your nose pocket is comfortable; not too tight and not too large. This will improve not only the comfort of your scuba mask, but your ability to purge your mask efficiently. There are increasingly different styles of scuba mask straps on the market. You may like the factory issue strap on your scuba mask or you may want to purchase a separate strap. Scuba mask straps are available in a single strap or a double strap design. The single strap should wrap around the centre of the back of your head. The benefit of the double strap is that you can position the top strap on the upper part of your head and the bottom strap on the lower part of your head to offer extra stability and comfort. Most scuba mask straps are rubber or silicone and fasten with a post-hole belt enclosure. Newer scuba masks offer a slide-lock type enclosure, which allows you to adjust the scuba mask quickly and easily when wearing the mask. Scuba masks are constantly improving. If you wear prescription glasses or contact lenses on a daily basis you can purchase a scuba mask without having to wear your glasses or contact lenses under your mask. Many manufacturers will create custom scuba masks which include your prescription in the front lens. A good sign you have chosen the right scuba mask for your face is when the mask stays on your face comfortably without using the straps to hold it in place. You should try this simple test with each scuba mask you try on for the first time: See our choices for scuba masks 1. Place the scuba mask over your eyes and mouth ensuring the mask is in the correct position. 2. Take a quick, light breath in through your nose and immediately start to breathe through your mouth as if you are scuba diving. This will create a slight suction between the scuba mask and your face. The scuba mask should stay on your face. If you must push the scuba mask against your face, or inhale repeatedly to help the mask stay on your face, the mask is not a good fit. 3. Keep the scuba mask on your face for approximately one minute. This will help you to determine how tight the seal is and how comfortable the mask is on your face. 4. Exhale gently through your nose to release the seal on your scuba mask and remove the mask from your face. There should be no mark on your face from the scuba mask. If there is a red line around your face from the seal of the mask, the seal was too tight or the mask is not the proper size for your face. Try the test a second time. If you still have a red mark on your face after you remove the mask, you need to continue your search for a scuba mask. Remember, a good scuba mask is one that's comfortable, doesn't leak and is easy to use."
Dec 01, 2008 | Vision Mares Pure Mask
Missing Instruction Manual
https://plweb.evenflo.com/faq_detail.aspx?faqid=4407 the above link is for the manual but here are the instructions. If you have two plastic harness adjusters located on the back of your seat please follow the following steps: On the very bottom of your car seat locate two metal anchors one on each side of the seat, pull the metal anchors out of position and turn them sideways and feed them through to the front of the seat. Release the buckle tongues and chest clip and pull the harness straps to the back of the seat while pushing the chest clips, buckle tongues and harness anchors through to the back of the car seat. NOTE: You may find it easier by pulling down the seat pad when feeding the straps through. All pieces will fit through the harness slots. Choose the appropriate slots for the new harness position. Push the harness anchors, harness straps, buckle tongues and chest clips back through to the front of the seat. Once the straps are completely pulled back through to the front of the seat, make sure the straps are not twisted by clipping the chest clip together and buckling the buckle tongues, then feed the metal anchors through to the bottom of the seat and clip anchors back into place. ********************************************************************* If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of the harness straps must be completed with the baby in the child restraint.
Aug 02, 2007 | Evenflo Embrace
382 people viewed this tip
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
