Tip & How-To about Cell Phones
BlackBerry - Synchronize data between mobile and computer
  1. Firstly you need to connect you blackberry device to you computer
  2. Then open BlackBerry Desktop Manager manual, if it didn't open automatically when device was connected to computer
  3. Then when the application is up look for synchronize and click it
  4. After which you will select the check box beside one or more action
  5. Then click synchronize
Cell Phones Logo
i have blackberry 8110 showing jum error 547
Hi, you need the desktop manager, and you need to download the current software version for that device, its going to wipe everything out on the device, but you will get the device to work. after you download the the software, you need to run it on your PC, and then use the APP loader on the desktop manager to install it to the device.
Step #1 Before starting make sure that BlackBerry Desktop Software is installed on the computer.
Step#2 Make sure that you have installed updated device software installed in your PC.
Step#3 Users can perform a full or selective backup of the data using the Backup and Restore tool in BlackBerry Desktop Manager by completing the following steps: Connect the BlackBerry device to the computer running BlackBerry Desktop Manager. Open BlackBerry Desktop Manager. Double-click Backup and Restore. Select Backup to perform a full backup or select Advanced to perform a backup of specific databases. Choose a location to save the backup file, then click Save.
Step#4 To perform a clean install of the BlackBerry Device Software, perform the following steps: Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager. Double-click the Application Loader icon. Click Next to start the installation process. Type your BlackBerry smartphone password, if prompted, and click OK. Click the check boxes next to the names of the applications you want to load, and then click Next. Click Advanced, and then click the check box beside Erase all currently installed applications. Click Next. Click the check box next to Do not automatically backup the application data during the loading process. Clear the box next to Backup and restore applications installed wirelessly. Click Next > Finish. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
Feb 23, 2011 | RIM Blackberry 8310 8320 8330 Curve 8100...
what i need to do when black berry has error jum 102
You need to run application loader...
This error occurs because all of the data and applications on the BlackBerry smartphone have been deleted.
The BlackBerry Device Software must be reloaded on to the BlackBerry smartphone.
To reload the BlackBerry Device Software you need the complete the following steps:
Before proceeding, make sure that the latest version of BlackBerry Device Software is installed on the desktop computer by completing the following steps:
To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 to 5.0, perform the following steps:
  1. Open BlackBerry Desktop Manager.
  2. Click Help.
  3. Select About Desktop Manager.
  4. Click the Device Software tab.
  5. Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider.
The following procedure will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the BlackBerry smartphone data before proceeding.
  1. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
  2. Double-click Application Loader.
  3. Click Next to start the installation process.
  4. Type your BlackBerry smartphone password, if prompted, and click OK.
  5. Select the check boxes next to the names of the applications to be loaded, and then click Next.
  6. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications.
  7. Clear the check box next to Backup up device data automatically during the installation process.
  8. Click Ok > Next > Finish.
  9. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.1 to 4.3, complete the steps 1-5 above and then proceed with the following:
  1. Click Advanced , and then select the check boxes beside Erase all application data and Erase all currently installed applications
  2. Click Next.
  3. Select the check box next to Do not automatically backup the application data during the loading process (if prompted).
  4. Clear the check box next to Backup and restore applications installed wirelessly (if prompted).
  5. Click Next > Finish.
Oct 31, 2009 | RIM BlackBerry Curve 8310 Smartphone
blackberry flip jvm error 545
  2. Click Help.
Warning: The following procedure will delete either all data, or applications on the BlackBerry smartphone. Back up the BlackBerry smartphone data before proceeding.
To perform a full backup of the BlackBerry smartphone data complete the following steps:
  1. Connect the BlackBerry smartphone to the computer running BlackBerry Desktop Manager.
  2. Open BlackBerry Desktop Manager.
  3. Click Backup and Restore.
  4. Select Backup to perform a full backup.
  5. Select a location to save the backup file, and then click Save.
To perform a selective backup for one or more databases perform the following steps:
  4. Click on Advanced.
  5. Select the database(s) on the right side selection window for Device databases.
  6. Select the Arrow that points to the left side of the screen to transfer the database(s) to include in the backup.
  7. Verify the database(s) are on the left side selection window for the Computer databases.
  8. Click on File in the menu located at the top left hand side of the Desktop Manager.
  9. Name the backup file and select a location to save the file.
  10. Click the option to Save once the location for the file is selected.
Once you perform backup procedure, kindly then perform the following steps:
  • Click Ok > Next > Finish.
  • When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
  • To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.1 to 4.3, complete the steps 1-5 above and then proceed with the following:
    2. Click Next.
    Oct 22, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
    I was downloding a backup on my bb, i didnt remember the password so it gave me an error 513 what do i do?
    The Blackberry Device Software must be reloaded on to the BlackBerry smartphone.
    1) Open BlackBerry Desktop Manager.
    2) Click Help.
    3) Select About Desktop Manager.
    4) Click the Device Software tab.
    5) Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider.
    For instructions on how to download the latest versions of BlackBerry Desktop Manager and BlackBerry Device Software follow the steps:-
    1) Click the BlackBerry Device and Desktop Software link. 2) Click the Download BlackBerry Device and Desktop Software link.
    3) Select the appropriate software from the drop-down list and click Next.
    4) Click the Download link.
    To perform a full backup of the BlackBerry smartphone data complete the following steps:-
    1)Connect the BlackBerry smartphone to the computer running BlackBerry Desktop Manager.
    2) Open BlackBerry Desktop Manager.
    3) Click Backup and Restore.
    4) Select Backup to perform a full backup.
    5) Select a location to save the backup file, and then click Save.
    To perform a selective backup for one or more databases perform the following steps:-
    1) Connect the BlackBerry smartphone to the computer running BlackBerry Desktop Manager.
    4) Click on Advanced.
    5) Select the database(s) on the right side selection window for Device databases.
    6) Select the Arrow that points to the left side of the screen to transfer the database(s) to include in the backup.
    7) Verify the database(s) are on the left side selection window for the Computer databases.
    8) Click on File in the menu located at the top left hand side of the Desktop Manager.
    9) Name the backup file and select a location to save the file.
    10) Click the option to Save once the location for the file is selected.
    1) Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
    2) Double-click Application Loader.
    3) Click Next to start the installation process.
    4) Type your BlackBerry smartphone password, if prompted, and click OK.
    5) Select the check boxes next to the names of the applications to be loaded, and then click Next.
    6) Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications.
    7) Clear the check box next to Backup up device data automatically during the installation process.
    8) Click Ok > Next > Finish. 9) When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
    To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.1 to 4.3, complete the steps 1-5 above and then proceed with the following:-
    1) Click Advanced , and then select the check boxes beside Erase all application data and Erase all currently installed applications
    2) Click Next.
    3) Select the check box next to Do not automatically backup the application data during the loading process (if prompted).
    4) Clear the check box next to Backup and restore applications installed wirelessly (if prompted).
    5) Click Next > Finish.
    Oct 16, 2009 | RIM BlackBerry Pearl 8100
    its says JVM error 513 reset
    2) Click Help.
    5) Select the database on the right side selection window for Device databases.
    6) Select the Arrow that points to the left side of the screen to transfer the database to include in the backup.
    7) Verify the database are on the left side selection window for the Computer databases.
    following:-
    2) Click Next.
    4) Clear the check box next to Backup and restore applications installed wirelessly(if prompted).
    139 people viewed this tip
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
