Tip & How-To about Philips Magnavox DVD/VCR Dual Player
How to clean a disc
  • Many times, all that a disc requires is a quick dusting, ideally using a soft cloth which has been specifically designed to clean a CD. To remove dust from a DVD or CD, use a soft, lint-free cloth. Hold the disc in a pincer grip with one finger along the edge and another in the hole in the middle, without touching the shiny portion,and gently move the cloth radially outwards from the middle. Do not rub the disc or move the cloth in circular motions, and make sure to avoid following the circular lines on the disc.
  • If the disc still looks dirty after dusting or if you are having trouble playing it, a more serious cleaning effort may be required. Several companies make special chemicals for the purpose of cleaning DVDs, but you can also use household cleaning supplies. One of the best cleaners is rubbing alcohol, but you can also use a warm water and mild soap solution instead if you wish. Avoid any heavy duty solvents when you clean a CD, as they can damage the disc.
  • Apply the cleaning solution to a clean lint-free cloth, and wipe the disc, again radially. When you clean a CD with a liquid material, make sure to wipe the excess liquid off, and never put the disc back into its packaging when it is still wet. Allow the cleaned disc to dry completely before attempting to play it again. When you clean a CD with alcohol or a specialized cleaning solution, many times the cleaner dries so quickly that this is not a major concern, but check for spots and/or marks which may interfere with clean play.
  • Even after cleaning, a disc may fail to play properly because of scratches. Some companies manufacture products which are designed to resurface discs, smoothing out scratches so that they will play again. Depending on how severe the damage is, these products can be quite effective, but it is a good idea to back up the data as soon as you have repaired the disc, in case it could fail again.
Let me know how this works for you.
Benjamin
Philips Magnavox DVD/VCR Dual Player Logo
keeps on pausing when playing cds tried using cd cleaner cd
It does not necessarily mean that the lens of the player might be dirty when you experience this kind of problems. It may be as a result of a weak lens or damaged disc.
You can try getting a disc with a clean face and try to see if it does the same thing. Also, make sure that you use a soft piece of cloth to clean the face of the disc before playing. Try to do this as gently as possible as it would help to remove some amount of hitches.
Also, the lens of the player might be weak and require replacement. In this case, no matter how you use the cd cleaner, it is not going to help unless you replace the lens.
Lastly, the recording of the disc might be bad and may require you to purchase another one. Sometimes, some discs have bad recordings and cannot play without hitches. This is a fault that comes from the production and not from your disc or player.
The best way to avoid these hitches are by doing the following.
1. Keep your discs in a clean and dust free environment.
2. Make sure you always keep the player closed so as to protect the lens from dust.
3. Ensure that you play disc with clean surface as scratched surface could result in a damaged lens.
Jul 04, 2011 | Audio Players & Recorders
The eyepiece lenses have something on the inside. Can they be removed for cleaning?
  1. Carefully clean your binoculars by firstly removing any dirt or dust from the main body and straps using a soft microfibre cloth. Avoid the lenses at this point using any form of cloth on the lenses before removing all dirt and dust particles first could destroy them.
  1. Gently remove all traces of grit, dirt or dust particles from the lenses using a soft lens brush or canned air specifically designed for the purpose.
  1. Waterproof binoculars can be rinsed gently under a tap but be sure to use on lightly running water, avoid high pressure water as it could damage your binoculars.
  1. Gently remove any remaining marks using lens cleaning tools such as a lens pen or lens cleaning fluid and lens tissue. Do not be tempted to use kitchen towel or anything else lying around that is slightly rough and may scratch the surface of the lens, only use a lens pen, lens tissue or a lens cloth. Gently wipe the lens using a circular motion working from the centre of the lens to the outer edge. NEVER apply lens cleaning fluid directly onto the glass (always apply to the cloth) and always ensure that the lens cleaning fluid you are using is recommended for the type of lens coatings that have been applied to your binoculars (Do not use general household glass cleaning products or products designed to clean computer screens or glasses. Such products could destroy the lens coatings of your binoculars if used).
May 15, 2011 | Tasco 7x50 Waterproof w/Imp. Compass...
how do you clea a disk
  • Many times, all that a disc requires is a quick dusting, ideally using a cloth which has been specifically designed to clean a CD. To remove dust from a DVD or CD, use a soft, lint-free cloth. Hold the disc in a pincer grip with one finger along the edge and another in the hole in the middle, without touching the shiny portion, and gently move the cloth radially outwards from the middle. Do not rub the disc or move the cloth in circular motions, and avoid following the circular lines in the disc.
  • If the disc still looks dirty after dusting or you are having trouble playing it, a more serious cleaning effort may be required. Several companies make special chemicals for the purpose of cleaning DVDs, but you can also use household cleaning supplies. One of the best cleaners is rubbing alcohol, but you can also use a warm water and mild soap solution. Avoid any heavy duty solvents when you clean a CD, as they can damage the disc.
  • Apply the cleaning solution to a clean lint-free cloth, and wipe the disc, again radially. When you clean a CD with a liquid material, make sure to wipe the excess liquid off, and never put the disc back into its packaging when it is still wet. Allow the cleaned disc to dry completely before attempting to play it again. When you clean a CD with alcohol or a specialized cleaning solution, often the cleaner dries so quickly that this is not a major concern, but check for spots and marks which may interfere with clean play.
  • Even after cleaning, a disc may fail to play properly because of scratches. Some companies manufacture products which are designed to resurface discs, smoothing out scratches so that they will play again. Depending on how severe the damage is, these products can be quite effective, but it is a good idea to back up the data as soon as you have repaired the disc, in case it fails again.
Let me know how this works out for you.
Benjamin
Jan 06, 2011 | Microsoft Xbox 360 Console
2,216 people viewed this tip
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
