Tip & How-To about Microwave Ovens
If your microwave isn't heating or getting hot
The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't see any obvious burnt parts (including a fuse and the diodes), then most likely the magnetron is done and a new microwave is the best way to go.
Let me know how this works out for you.
Benjamin
Microwave Ovens Logo
My microwave won't warm anything up. Everything works, except it doesn't heat my food.
The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't seen any obvious burnt parts (including a fuse and the diodes), then most likely the magnetron is done and a new microwave is the way to go.
Benjamin
Aug 18, 2010 | Whirlpool MH6150XLS Microwave Oven
the microwave will not heat up any food
Benjamin
Aug 15, 2010 | GE XL1800 1100 Watts Microwave Oven
The microwave will kick on but the food will not be heated
Benjamin
Aug 15, 2010 | Maytag UMV1152BAS Microwave Oven
hello, my microwave is not heating the food up and gives off a slight smell when attempting to heat the food. thanks
The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't seen any obvious burnt parts, then most likely the magnetron is done and a new microwave is the way to go.
Benjamin
Jul 19, 2010 | GE Microwave Ovens
magnetron? Not heating food anymore.
Yes, The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't seen any obvious burnt parts, then most likely the magnetron is done and a new microwave is the way to go.
Benjamin
Jul 19, 2010 | Amana Radarange Microwave Oven
427 people viewed this tip
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
