Tip & How-To about Office Equipment & Supplies
PRINTER SELECTION
Most computers will already have the correct printer selected. However, if you are attempting to print and the computer gives you no errors yet you still do not see a printout, check the selection in the "Name" drop-down box in the File >> Print menu in the program you are using where you want to print your file. If the name of the printer selected does not correspond with the name of the printer you are attempting to print to, change your selection. Some labs have multiple printers; be sure to look
around each printer for your printouts before changing anything in the printer's menu. In general, the computer classrooms should use N4525. If that printer does not seem to be working, try the N24 if that's listed as an available printer.
canon mp258 printer can not fine driver on my computer it only picked up the scander part
Possible causes of failure:
1. Error install driver process
How to install the correct driver canon
- Do not connect the printer to the computer. So, turn on the printer but do not connect the printer to the computer.
- Insert the driver CD and do the install process.
- At the time of the install process, it would appear the request connect the printer to the computer.
- Connect the printer to the computer. The computer will detect the printer, and install process will continue until completed.
- Then, press the START - Printers and Faxes - Right click the Canon MP258 series Printer - select Printing preferences - click Maintenance - Print head alignment - Align print head - OK - etc. Perform print head alignment until completion (approximately 3 times the heat print alignment). Print head alignment, to configure the printer and computer.
- After the print head alignment is completed, the printer is ready to use.
Install the wrong driver canon
- Connect the printer to the computer, then perform install process.
- Solution: disconnect the USB cable from the printer to the computer, then uninstall the drivers and applications that are already installed, then restart the computer.
- Repeat the process to install in the correct way.
2. Drivers don't support the operating system
If you need a Canon MP258 driver download here:
Canon Support and Download
- Follow the link
- Product category = Inkjet Multifunctional Printers
- Product series = PIXMA
- Model = PIXMA MP258
- Document type = Drivers & Software
- Click Find
- Select OS = example : Windows 7
- Download driver printer; MP250 series MP Driver Ver.1.04
- Download driver scanner; MP Navigator EX Ver. 3.04
I hope this information helps. Thank you for using FixYa!
Oct 07, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
an my printer show E-01 you know what s that mean an how i can fix it
Attempt to disconnect from the computer to perform reconnections. Restart the computer to acquire the new settings. The computer should diagnose the condition if any still exists. Also, perform printer supplies examinations for depleted ink paper or event stuck paper and malalligned compartments that may obstract printer commands from computer. Also, attempt to examine the prorgams on the computer attempting to print. Usually program errors from the computer either as copyrited materials or malalligned or selected data display printign errors.
Jan 29, 2011 | Office Equipment & Supplies
How do I get my laptop to to print on a Lexmark printer without the software?
Your printer will not print without the correct drivers installed in your computer. To locate and download your drivers, you can visit the Lexmark website.
Just enter the information requested and the website will direct you to the correct drivers.
Also, you'll need to know your printer's model number to obtain the drivers you need.
Lexmark website, click here: http://support.lexmark.com/index?page=localeSelect&jumppage=home
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks!
Feb 03, 2010 | Apple MacBook Laptop Computer Mac...
Error E000733-0001
There is a poor contact between the DC control PCB and main controol PCB .
to clear this error press * 28 * and select copier &select function & select clear and press OK
((*)means additional function button on display).
Jul 29, 2008 | Canon (6981A002AA) for imagerunner 2200,...
165 people viewed this tip
jasbo
jasbo
