Tip & How-To about Computers & Internet
How to Fix Touchpad on a Laptop
The touchpad of your laptop is a most important and frequently used input device. If your touchpad stops functioning, it may be difficult for you to use your laptop. Touchpad normally faces following issues.
Laptop Problems and Their Solutions
Problems with the driver
Computer hardware communicates with your computer through real time software called driver. Drivers control computer hardware. It is possible that virus or human activity may damage the driver. You can check your driver's status through computer's device manager. You'll see a yellow color indication under "Mouse and other pointing devices" heading. You can download new driver form your laptop's manufacturer website.
Problems with connection
Touchpad's connection with motherboard is delicate. It can be broken due to heating and other inner problems. So, if there is no problem with the driver, then the connection of the touchpad to the motherboard may have broken.
Misuse
Touchpad of the laptop is the most delicate input device. Some people tap on it too hard or use a shrill tool as an alternative of a finger. This can damage the pad.
Fn Keys
Touchpad driver is slightly different from the other devices that need drivers to function properly. It came with an operating system that you don't need to re-install it. Laptop keyboard comes with many functions than the common keyboard. It has Fn keys which are called function keys. Sometimes, your laptop's touchpad stops working because you accidentally hit some one of the Fn keys. You can follow these instructions to make your laptop touchpad working again.
1- Search for Fn key on your laptop keyboard. It is commonly located next to the Ctrl key.
2- Now search for F1 to F12 keys on the laptop keyboard. These keys control sound, brightness of the screen, wifi etc. They are located on top of the keyboard. Look for the key which has icon on it that looks similar to the touchpad.
3- Let's take an example of Toshiba laptop. It uses F10 key to enable or disable touch-pad. Hold down Fn key along with F10 key to enable the laptop touch-pad.
Cleaning the laptop touch-pad
It is a good practice to clean your laptop touchpad. To clean it, take a cloth dampened with sprit. Wipe your touchpad off with that cloth.
Laptop touchpad work best in moderate temperature and gasping environment. Moisture, excessive heat, can damage it. Try using your laptop with tidy hands. Sweaty and dirty hands can cause problems.
Computers & Internet Logo
how to reduce the sensitivity of a laptop touchpad running windows 8
A touchpad is simply a mouse. Type "mouse" in the search box to bring up the mouse settings. The adjustment mouse and touchpad should be there. Another way is to go to "control panel" and find mouse there to change the settings. It may read "input devices".
Feb 07, 2015 | HP iQ775 19" TouchSmart Desktop PC
mousepad don't work
have you turned the mouse pad off using one of the function keys?
look on the laptop until you find something similar to a touch pad try pressing the fn keys once and use keypad and try again, if this doesn't work go into devices and make sure the touchpad is set for the default input device
Dec 22, 2013 | Sylvania Computers & Internet
cannot figure out how to restore the touchpad functionality on my hp6730b
Try pressing the function button + F7
FN + F7 - this is if you have all the proper drivers installed.
There are several "functions" that laptops have that help to minimize the keyboard size, they add these functions by holding the function key and pressing the corresponding function that you would like to perform. I do not have your specific model, however there generally is a "function" to disable the touchpad for people who type frequently and use a mouse.
Feb 28, 2013 | HP Compaq 6730b Notebook
keyboard unlock
Like most modern laptops, IBM/Lenovo laptops feature a built-in touchpad that you can use as a substitute for an external mouse device. If you experience a non-functional or "locked" touchpad, then you have one of two possible problems; either the touchpad's drivers are corrupt or a user has manually locked the touchpad. In either case, you can unlock your touchpad and restore it to functionality quickly.
Open your web browser and paste the following URL in the address bar:
Click the "Download" button and then click "I agree" to save the Lenovo touchpad driver installation file to your computer. Double-click the EXE file that you downloaded. Doing so opens the driver's installation wizard. Follow the on-screen prompts to re-install your Lenovo's touchpad drivers. If your locked touchpad is due to a corrupt or outdated device driver, then your touchpad is now unlocked and functional. Activate Touchpad Hold the Windows logo key and press the R key to open a run command box. Type "control mouse" in the box and press Enter. The Mouse Properties control panel window opens. Click the "Device Settings" tab. Click the Lenovo Touchpad in the "Devices" list and click the "Enable" button to activate the Touchpad. Click the "OK" button to save your changes. Your Lenovo's touchpad is unlocked and ready for use. Lenovo support
http://consumersupport.lenovo.com/vn/en/DriversDownLoads/drivers_show_120.html
Feb 24, 2013 | Lenovo Computers & Internet
Touchpad doesn't work
Step 1:
The touchpad of any laptop is always subject to heavy use.
Most touchpads are designed for their durability to sustain the daily wear and tear for the lifespan of the laptop.
However, there may be instances or accidents that cause the touchpads to malfunction or stop working entirely.
There are ways to troubleshoot such problems and there are also remedies to salvage the touchpad's functionality without heavy repair or replacement cost.
Determine What's Wrong
A laptop's touchpad basically provides the functionality of a mouse for a desktop PC, typically with two buttons located just below it acting as the left and right click buttons on a desktop computer. A touchpad may be damaged by excessive use or foreign substances such as water, dirt or food items. Hit the "Windows" button on the keyboard and then use the right-left keys (or hit 'C') to open "Control Panel." From there, again use the right-left keys to get to "Mouse" and then hit "Return." Use the right-left keys to toggle between the tabs and open each to investigate whether any boxes had been improperly clicked by accident that cause the touchpad to become unresponsive. But if any of these steps fail to remedy the problem, then the touchpad may need to be repaired or replaced. b> Repairing/Replacing Touchpad b> A touchpad assembly cost $100 or more and that's not including replacement installation. Hiring a specialist to replace a damaged touchpad, including parts and labor, may easily cost $200. Unless the laptop in question is worth well over $1,000 and the touchpad is deemed a necessity, such repairs are rarely worth the cost. Attempting to replace the touchpad without certain expertise in laptop assembly may be dangerous and/or destructive. Also, getting a replacement part that's not compatible with the laptop may have catastrophic results, including irreversible damage to the laptop. Long-Term and Better Solution b> The simplest, and best, solution to a malfunctioning touchpad is to replace its functionalities with an external mouse. Most PCs sold after 2000 come with USB ports and getting a USB mouse either a corded or a cordless one--will remedy the problem. A cordless USB mouse may be bought for as little as $10 and some of the better-designed ones allow the user to tuck the USB stick inside the mouse's belly when not in use. Even when a touchpad is working properly, a laptop user should be advised to plug in a mouse anyway whenever possible as touchpads are notoriously difficult to use and also leaves the user in an ergonomically incorrect position.
http://www.microsoft.com/ b> http://www.streetdirectory.com/travel_guide/116002/hardware/touchpad_keyboard_for_personal_computers__pc.html
Feb 19, 2013 | Computers & Internet
7,532 people viewed this tip
David Payne
David Payne
