Tip & How-To about Audio Players & Recorders
How to Upload Music to your iPod Touch
Instructions:
1. Open iTunes on your computer.
2. Plug the iPod USB connector into a USB port. Plug the other end of the connector into the bottom of the iPod Touch.
3. Look for the iPod Touch to show up in the Devices column in the middle left corner of the iTunes program screen. Once it does, you have two options. You can have all the songs/music from your personal music library/file sync with the iPod Touch every time you plugged into the computer, or you can create a playlists and manually selecting them for syncing.
4. Click on the iPod Touch symbol in the Devices column once you've decided which method of music management is best and suits your preference. A screen will pop up, giving you the summary of information about your iPod. Click on the options you want, then proceed to the bookmarked section labeled "Music" in the upper middle section of the page.
5. Click the "Sync" button in the bottom right corner of the screen. When the music has finished its sync process, a message at the top will appear "iPod Touch sync is complete. OK to disconnect.
unlock
Unlock an iPod Model A1199
Although the second generation iPod Nano (also known as 2G) uses a four-digit pass code that prevents unauthorized access to your iPod by locking the screen, you can also unlock the device by plugging it into your computer's USB 2.0 port.
When the 2G iPod Nano is connected to the computer it is synchronized, and automatically unlocks the screen according to the official Apple site.
In order to successfully unlock the Nano it must be plugged into the primary computer used for synchronizing content.
Click "Start," "All Programs" and "iTunes" on your PC's desktop, or click "iTunes" on the Macintosh's desktop dock.
Plug the iPod Nano's cable into the docking port on the iPod Nano.
Plug the other end into the USB port on the computer to open iTunes.
Click "Controls" at the top of the iTunes' menu, and select "Eject iPod."
The iPod Nano's screen will be unlocked once it is ejected from your computer.
Manual Guide download
http://manuals.info.apple.com/en_US/iPod_nano_2nd_Gen_Features_Guide.pdf
Unlock an iPod Nano Code
With the latest iPod Nano model, you can set a four-digit code and lock all intruders from accessing your iPod.
In order to use the device's functions again, you need to enter the correct code.
However, if you happen to lose or forget the code, you will need to find another way to unlock your iPod Nano.
Plug the iPod USB cable into the bottom of your iPod Nano.
Plug the other end of the USB cable into a free USB port on your Mac or PC computer.
Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
Select your iPod Nano from the "Devices" list in the main iTunes window.
Click on the "Sync" button to make a connection between your computer and your iPod Nano.
Click on the "Eject" symbol once the syncing process is complete.
Remove your iPod Nano from the USB cable.
The iPod's lock code will now be reset and you will be able to access all features again.
Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again.
Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
iPod Support
http://www.apple.com/support/ipod/
Jul 24, 2013 | Apple iPod nano
how do you you hook up an ipod to a computer
  1. Connect the small end of the USB cable to a high-powered (2.0) USB port on your computer.
  2. Connect the large end of the USB cable to your iPod's dock connector, which is located on the bottom of your iPod.
  3. Open the iTunes software on your computer. When your computer recognizes your iPod, an iPod icon will be displayed in the device list on the left-hand side of the iTunes software window.
Dec 06, 2009 | Apple iPod classic MP3 Player
I have an ipod nano 3rd generation and it won't unlock
1. Plug the ipod USB cable into the bottom of the iPod Nano.
2. Plug the other end of the iPod USB cable into a free USB port on a Mac or PC computer.
3. Open the iTunes application by clicking on the Dock icon on a Mac or using the Start menu on a PC.
4. Click on the name of your iPod Nano under the "Devices" list in the iTunes window.
5. Click on the "Sync" button to establish a connection between your iPod and the computer.
6. Click on the eject symbol next to your iPod's name after the syncing process has finished.
7. Unplug your iPod Nano. The device will be unlocked and you will be able to access all normal features again.
Sep 24, 2009 | Apple iPod nano 3rd Generation
i have a used iPod shuffle that works but iTunes does not respond
Here are the instructions for how to setup and register your IPod
· Insert the CD that came with your iPod into your computer.
· Open My Computer, then double-click the iPod CD to start the installation.
· In the resulting dialog, choose your preferred language from the menu choices, then click OK.
· The iPod for Windows Install.
Wizard starts up. Follow the instructions to install ipod software onto your computer, connecting your iPod to your computer (if asked) as follows:
  • To connect iPod shuffle: Remove the USB cap and plug the USB connector into a high-powered USB port on your computer.
Note: High-powered USB ports are generally the ones that reside on your computer or on a powered USB hub. If you want your iPod battery to charge while connected, avoid using the USB port on your keyboard or non-powered USB hub.
· When your computer recognizes iPod, it may update software on your iPod if needed (click Update if you get a dialog that says your iPod needs to be reformatted or restored). When finished, your iPod software will be installed at the default location, C:Program FilesiPod (unless you choose another folder).
· The installer will then install iTunes if it isn't already installed on your computer, or if you have an older version installed than the one that came on your iPod CD.
· When the installation is complete, follow the instructions to restart your computer.
· Once your computer is back up, you should be greeted by the iPod Setup Assistant (if your iPod is still connected). Type a name for your iPod in the top field.
· Choose the "Automatically update songs on my iPod" checkbox if you want to sync your entire itunes music library and playlists to your iPod each time you plug it in. If you want control of what goes onto your iPod, deselect this checkbox.
· If you have an iPod with a color display, you can have iTunes automatically copy your photos to your iPod (using your settings in iTunes preferences) to fill any remaining space by choosing the "Automatically copy photos to my iPod" checkbox. Then choose a folder from the Synchronize photos from menu. If you prefer to copy photos manually, deselect this checkbox.
· Click Next to go to the next screen. If you'd like to register your iPod at this time, click Register My iPod. Click Finish to end the setup process and open iTunes (you should see your iPod hanging out in the iTunes Source pane.
Hope this helps,
Thanks,
Prince
Aug 06, 2009 | Apple iPod shuffle MP3 Player
298 people viewed this tip
 Grubhead
Grubhead
