Tip & How-To about Cameras
How to make your own cheap dry box
Hi all,
I would like to share tips of making your own dry-box
What you`ll need are:
-1 plastic compartment, you can find it easily at the supermarket
-1 pack of silica gel / dehumidifier
-1 hygrometer (optional)
-1 thermometer (optional)
It costs me only US$ 4 only (hygrometer and thermometer not included), and this DIY dry-box keeps my camera and lenses safe from fungus and humid weather
Hope this tips is worth!!
Cameras Logo
what is the dash compartment strAPS CALLED that hold the door on dash open.
Hi Donald:
They are usually just as you describe, "dash compartment" or "glove box" restraining strap.
They are often called "broken".
If you try using Google with the make, year, and model, with the description "glove box parts diagram" you might just get all the info that you need.
Sep 11, 2016 | Cars & Trucks
The plastic tray at bottom in the fridge just above freezer compartment has a slight crack. Can this be repaired
Hi, they can be repaired with a plastic solvent glue usually comes in tubes. Make sure the tray is dry and at room temperature before putting the glue on. It should slightly melt the plastic and fuse it together. I would put another coat of glue on once the first coat is dry.
Dec 24, 2015 | Frigidaire Refrigerator White Fridge &...
I need a replacement battery compartment for my pony is there anywhere where one of these is available?
Call Hasbro's Customer Service and see if they can offer any suggestions. If they make any other FurReal friends that are so large that they require 6 D cells, then the box would probably fit. If they don't you'll have to do some internet searches for "Plastic On Off Battery Compartment" or see if HASBRO can tell you what the part number was and you can try searching for that. Hope that helps.
Dec 15, 2011 | Hasbro Furreal Friends Butterscotch Pony
How do you install the batteys in the stanley tripod legs?
To replace the batteries in each side of the 3-in-1 tripod light, you'll need to slide each light out of the central frame. Once each individual light is out on its own, you should be able to easily unscrew its bottom, giving you access to the battery compartment. Unlike the original Stanley tripod light, the actual tripod legs no longer hold the batteries.
On the original Stanley tripod LED light design, the black tripod leg tips simply unscrewed after you popped them out into the "stand" position. Much simpler to figure out.
Jun 25, 2011 | Stanley 3in1 Tripod LED Flashlight 95155
air filter replacement
Per Hondacarforum.com
"look for your air filter box. its a big square box on the right hand side of the car under the hood. you cant miss it. ther should either be clips or screws holding the box together. you have to get the top off of it to get to the filter... just replace the filter, and put the top back on and ur good"
per Chinogang Senior Member
May 06, 2009 | 2004 Honda Civic
2,195 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
