Tip & How-To about Kenmore 40494 / 40495 / 40499 Electric Single Oven
How to Replace an Electric Oven Element
Replacing an oven element is quite simple that almost anyone can do it.
  1. First pull the oven away from the wall and unplug it.
  2. Next, remove the rear panel from the oven.
  3. Now disconnect the element from the wires that power it, they should pull straight off of the element.
  4. Remove any screws that might be holding the element in place, check both in the oven and on the back. It depends on the make and model where the screws may be.
  5. Last, remove the element by pulling it out through the heating chamber, and replace with the new element. Simple as that.
For replacement parts, check repairclinic.com which I recommend, otherwise local stores may have what you need or the manufacturer themselves.
Congrats, you have just learned how to replace an element.
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
replacing element in oven
Pull out the oven & unplug it. If element is screwed to the back wall of the inside of oven, you can remove the screws to detach the element or if not, there should be a metal protective plate at the rear of the oven to access the element screws/wiring. Replace with same.
Mar 01, 2015 | Frigidaire 30" Self-Cleaning Freestanding...
top oven element not working
Well, to ensure the element is bad, you can take an ohm meter to the contacts of it and measure the resistance. It should be around 20 ohms. If it is much greater or infinite, the element is bad. To get to the contacts you will need to unplug the oven, pull it away from the wall and remove the rear panel. Then disconnect the element wiring and touch the probes from the meter to the contacts on the element. You can order a new element locally or from repairclinic.com. Let me know what you find.
Benjamin
Nov 03, 2010 | Stoves Ovens
heating element is broken - lower (baking) element. What part do I need and is this user-serviceable?
With the model number you can order a new element from repairclinic.com
You can remove it by pulling the oven out from the wall, unplugging it, removing the rear panel, and then disconnecting the element and swapping it out. Fairly simple for anyone with patience.
Let me know how this works out for you.
Benjamin
Jan 10, 2010 | GE Ovens
Double oven / convection not working
It is likely that the convection element is burned out and needs to be replaced. If all other functions are working then this is the place to start. Teh back panel inside of the oven can be removed by removing the 4 visible philips screws on it. The element should look smooth and round, if not then it needs to be replaced. Be sure to turn power off to the oven before replacing it. Remove the screws that fasten the element to the back wall and gently pull the element away from the wall an inch or so. the wires will be exposed and can be unclipped from the element do not let them fall inside of the back of the oven or you will have to remove the oven from the wall to get at the back panel. Install the new element in the reverse procedure. If the element looks good then it will have to be tested with a multimeter to verify that it is still good before proceeding to check the selector switch for burn marks.
Dec 10, 2006 | Bosch HBL 455 Stainless Steel Electric...
1,496 people viewed this tip
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
