Tip & How-To about Computers & Internet
Dust is the enemy of your computer
You should always make sure that your laptop is kept away from dust; this can clog fans and even vents which will cause your laptop to heat up significantly. To help protect the laptop it is important to look for a way to protect your computer such as keeping it on a table or a desk.
Computers & Internet Logo
One spot on my Sony GTX900ES board gets extremely hot right away turned on and smells hot. Everything works correctly but haven't kept it on for very long cause of the heat. I know where it's heating up but have no idea what it is called. It's the tallest U shaped piece of copper amongst three two others all with a black component attached to the inside center by a single screw. It has some white silicone smeared on it. What is it?
It is the fan and heatsink assembly.
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Jan 13, 2013 | Computers & Internet
Asus N61JQ Has overheating problem
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
Nov 20, 2012 | Computers & Internet
how to fix if it always hang and turn-of by itself while you're still using
Aug 27, 2012 | Toshiba Computers & Internet
my laptop keeps turning off
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Apr 29, 2012 | Computers & Internet
MY DELL E 1505 IS OVER HEATING AND GETS HANG
Due to their small size and lack of ventilation, laptops tend to overheat more than desktop computers. A noisy cooling fan that runs continuously is one sign that your laptop is overheating. Laptop overheating can also cause a loss of performance, system crashes, and even permanent damage to components. The goal is to make sure your laptop has proper ventilation and is kept as cool as possible.
1.Always use your laptop on a tray, desktop, or other cool surface. If you use it on your lap, make sure clothes, upholstery or bedding are not blocking the case vents. Blocked vents are the number one cause of laptop overheating.
2.Use an aerosol air duster, or can of compressed air, to blow dust from the air intake vents. Air intake vents are a set of slots on the side or bottom of the case that allow cool air to flow into the laptop.
3.Clean the cooling fan exhaust system. The cooling or CPU fan is located on the side or back of the case. A clogged CPU fan vent keeps hot air trapped inside the case. Use an aerosol air duster to loosen the debris, then use a vacuum cleaner with crevice tool to vacuum out the dust and dirt.
4.Use a commercial laptop cooler. A laptop cooler pad is an external USB powered fan that serves as a base for your laptop. If your laptop generates a lot of heat, even with a clean cooling system, a laptop cooler will extend the life of your laptop.
5.Adjust your BIOS settings. Most laptops have features built into the system BIOS that allow fan speed, CPU temperature alarms, and other settings to be adjusted. Read your owner's manual to learn how to enter the BIOS and change the settings for your particular laptop model.
Sep 26, 2011 | Dell Inspiron E1505 Notebook
260 people viewed this tip
David Payne
David Payne
