Tip & How-To about Computers & Internet
Dell Laptop battery won't charge.
Apply the adapter plug with force! and hold it in HARD until you see the laptop charging. it's worked for almost everyone i know, plus me. it may take a couple tries, but usually, this is the case.
Hope this helps.
Cheers!!!
Computers & Internet Logo
Acer Aspire 5610 battery won't charge. AC chord is plugged in. Battery reads at 3%.
either dead battery or burned out power supply try buying universal one from radioshack or best buy make sure you can return it if its not solving the problem.
Mar 02, 2011 | Acer Aspire 5520-5908 Notebook
battery wont charge
Have you ever noticed any messages at power up regarding the AC adapter type? If not, then it sounds like your battery is dead. Apply the adapter plug with force! and hold it in HARD until you see the laptop charging. If still problem remains then you need to replace it or get it repaired.
Jan 07, 2011 | Computers & Internet
How do i know if its my battery thats not working or is my universal adapter not strong enough to charge it ?
- Your laptop should have an indicator that tells you that its battery is being charged (when plug-in to charger) or discharged (when running of battery).
- The universal adapter will have several voltage settings: make sure you have selected the correct voltage (DO NOT USE VOLTAGE SETTING HIGHER THAN REQUIRED OR YOU WILL DESTROY YOUR BATTERY REGULATOR!)
Dec 29, 2009 | Office Equipment & Supplies
My power won't turn on. The battery and the cable
Check the power adapter with a multi-meter, the voltage of the power plug that plugs into the power socket on the laptop should be slight higher than the voltage that is printed on the label on the adapter.
If it is faulty, there are replacement power supplies available on the Internet or at your friendly computer shop.
If the adapter is OK then the power socket on the laptop is faulty or this socket has a dry solder joint connection on the motherboard.
You can test this by wriggling the power plug when it is connected to the laptop, if the charge LED flickers and if you hold this plug in a certain position the charge LED stays on without flickering, then the power socket is faulty.
This can be repaired, but requires the laptop to be completely
disassembled. I suggest you get a quote first.
Oct 07, 2009 | Acer Aspire 3680 Laptop
Charging
The ac adapter connector probably needs to be re-soldered or replaced. You will have to have it serviced.
May 31, 2008 | Acer Aspire 3680 Laptop
137 people viewed this tip
David Payne
David Payne
