Tip & How-To about Computers & Internet
Helpful commands when you lost Windows 7 password
If you lost Windows 7 password, you can not only use a Windows password reset disk, but also use some easy and useful Windows 7 commands to reset it. Followings are simple guides for your lost Windows 7 password recovery or reset with commands, you can make full use of the commands lusrmgr.msc and Control userpasswords2.
Tips 1: Use command lusrmgr.msc
Lusrmgr.msc is a helpful command if you forgot Windows 7 password. When you press Enter after entering lusrmgr.msc in the Start search box, it will pop up the Local Users and Groups screen. Double-click the Users folder to view all users of your Windows 7 machine. Then you can easily reset a lost Windows 7 password by right-clicking its user name to select Set Password.
Note: You can also enter the Local Users and Groups by clicking Control Panel > Administrative Tools > Computer Management > System Tools > Local Users and Groups
Tips 2: Use command control userpasswords2
Control userpasswords2 can help you open the classic User Accounts dialog, where you can change the forgotten or lost Windows 7 password, and enable Windows 7 auto logon.
Please be aware of that the text search box in the start menu cannot recognize Control userpasswords2. To use the command control userpasswords2, you need to press Win Key and R key together to open the Run box and input the Control userpasswords2 in it. When you hit Enter, the classic User Accounts dialog will come up. You'll find all the users for the computer are displayed on it. Just select the target user name and then click the Reset Password button to reset the forgotten password.
Note: If you want to skip the logon screen whenever you log on to computer, you can uncheck the box that Users must enter a user name and password to use this computer, select the User Name and click Apply button to enable auto logon for this selected account.
Efficient Windows Password Recovery Software
Please note when you forgot Windows 7 password and cannot access computer again, the above commands will now work for you. At that time, you may restore to Windows password recovery software, which is the best solution when you forgot Windows password (Of course, you can also use a Windows password reset disk if you have, or reinstall computer if nothing important on your Win 7 machine).
Here we strongly suggest you try Windows Password Breaker, which allows you to create a bootable CD/DVD or USB flash drive to remove lost, unknown or forgotten Windows 7 password in only 4 steps.
Step 1: Download Windows Password Breaker.
Step 2: Burn a bootable CD/DVD or USB flash drive with the program.
Step 3: Boot from CD/DVD or USB.
Step 4: Remove forgotten Windows 7 password.
Now you can log on your Windows 7 again with no password, it's so easy and efficient for you to reset lost Windows 7 password with no data loss, saves you much more time and trouble.
Computers & Internet Logo
I forgot my password to log onto microsoft windows ce on my netbook and now i can use it at all. How can i recover my password or reset everything?
There are three options that you can follow: Option 1:use password reset disk if you have made one. this is an easy way to reset just follow the instructions. Option 2:use command prompt to reset Windows 7 password, but you should login your Windows as administrator Option 3:use third party program to reset lost windows 7 password.Windows Password Recovery Tool is a good choice that you can try, you can reset the lost password in several minites
May 19, 2014 | Computers & Internet
How to enable Windows 7 administrator account and reset lost Win 7 admin password There are two parts for your Windows 7: * Enable Windows 7 administrator account * Reset lost Win 7 admin password With 240 million licenses sold out in one year, Windows 7 has been proved to be a successful product of Microsoft. Compared with its previous versions like Windows XP, it has many improved features. The built-in administrator account is one of the features. In Windows XP, there is a default administrator account after installation. But the built-in administrator account is disabled by default in Windows 7. To enable Windows 7 administrator account and assign a password to it, you can achieve it in 2 methods. Part I: Enable Windows 7 administrator account Method 1: Use Command Prompt The easiest way to enable the Windows 7 built-in administrator account is to use the Command Prompt. 1. Click Start and type CMD in the search box. Right-click CMD and select Run as Administrator. 2. Click Yes when prompted to allow the Command Processor to run. And then the command prompt will appear. 3. Type net user in the command prompt window, and then hit Enter. All the Windows account user names will be listed. You'll also see the Administrator account, but now it is not enabled. 4. Type net user administrator /active:yes and hit Enter to enable Windows 7 admin account. Now the Windows 7 administrator account is created. To create the Windows 7 administrator password, you can follow the below steps: 1. Switch to log on Windows 7 with the administrator account. 2. Click Start, Control Panel, User Accounts and Family Safety and User Accounts in order. You'll enter the screen where you can make changes for your account. 3. Click Create a password for your account on the screen. 4. In the coming screen, type and confirm your Win 7 admin password. 5. Enter password hint and click Create Password. Now your Windows 7 admin password is successfully created. Method 2: Use Local Users and Groups 1. Click Start and type lusrmgr.msc in the search box, and then hit Enter. The Local Users and Groups screen will come up. 2. Double-click the Users folder. And all the Windows 7 account will be displayed for you. 3. Right-click the Administrator account and select Properties. 4. Uncheck the "Account is disabled" check-box and click OK on the administrator properties screen. Now Win 7 admin account is enabled. To set a password for the enabled Windows 7 administrator account, follow the steps as below: 1. Right-click the Administrator account and select Set Password. 2. Click Proceed to go on your operation 3. Type and confirm your new Win 7 admin password and click Ok 4. Close the Local Users and Groups screen. Now the Windows 7 administrator password is assigned to your Windows 7 admin account. Part II: Reset lost Win 7 admin password Windows 7 administrator password reset Tips: Note 1. Please remember to create a Windows 7 password reset disk after assigning Windows administrator password. It allows you to change your forgotten Win 7 admin password when you are locked out of Windows. Note 2. If you forgot to create the password reset disk, you can choose to use Windows Password Breaker to help create a Windows 7 password reset disk rather than reinstalling the system. Now follow the steps to create the disk to reset Windows 7 password. step 1. Download and install Windows Password Breaker. step 2. Run the program and burn a Windows password reset disk. Step 3. Reset Windows 7 administrator password with the disk. It is an easy and safe way for Windows 7 admin password reset.
Nov 02, 2010 | Computers & Internet
forgot administrators password, have no reset disc, windows 7. need pathway in command promt
This article describes how to reset windows 7 password without disk when forget login password and locked out of your laptop or computer.
If you are still bothered about forgetting windows 7 password and have no reset disk, the methods described in this article will help reset the lost password with or without disk. You just need a few minutes to read these methods in this article, and pick the right one to take it to carry out.
Method 1 and Method 2 describe how to reset a user account password under the condition that you can login your comptuter with another administrator account.
Method 3 shows how to reset a lost password with windows 7 password reset disk which you have created before forgetting login password.
Method 4 tell you how to reset or recover windows 7 login password with a password recovery software.
Sep 11, 2013 | Computers & Internet
Lost password for windows 7. Cant login
Lost windows 7 passwords just isn't a serious problem. I know a fairly easy solution to recover lost windows logon passwords, just need to create a bootable disk or Usb memory card to recover forgotten windows password, I have made a bootable CD with the program Windows Password Seeker and reset my admin password successfully. You could Google windows password seeker or visit their site: http://www.passwordseeker.com
Dec 13, 2010 | Computers & Internet
244 people viewed this tip
David Payne
David Payne
