Tip & How-To about Wd40 Open Stock Lubricants 10110 SEPTLS78010110
Door ajar light stays on?
Does your vehicles door ajar light stay on all the time?
A quick and easy solution that fixes it most of the time is to spray WD40 into the latches. Yes WD40. Spray some into the latch, don't be shy you can wipe off the drips, then open and close your door about 5 times. Spray some more in there and open and close the door a few more times. Do this to each door and even the hatch. You will be surprised when the interior light finally goes out and the door ajar light finally shuts off.
Hey and while you are at it why not give the hinges some lovin too, spray some WD40 in there when you spray the latches. Might as well get rid of the creaky door at the same time as turning off the door ajar light.
Good luck and have fun.
Wd40 Open Stock Lubricants 10110 SEPTLS78010110 Logo
2003 Ford Excursion interior lights stay on after truck is turned off for 20 to 30 minutes, and door ajar light is always onbut all doors are closed.
One of the door switches is not showing an open contact. Which sugnals the computer that a door is ajar. Try blowunyg comoressed air into every door sqitch including the rear hatch. Afterwards, spray each switch with WD-40. Good Luck.
A thumbs up would be greatly appreciated if this answer is helpful to you. 2003-ford-excursion-interior-lights-stay-gul110xrrkztwfkelv0nmxtt-3-0.jpg
Jul 21, 2012 | 2003 Ford Excursion
Door ajar problem checked all doors theyre not open and lights stay on
Spray wd40 on the door latches. Happened to me a few months ago. The latch gets stuck and cannot reach the necessary position to turn off lights and door ajar notification.
May 21, 2010 | 2003 Ford Explorer
my door ajar light stays on constantly. therefore my doors don't automatically lock when put into drive and constantly dings when the keys are left in ignition. what's up withthat?
take and spray wd40 on the latches and open close the door a few times and that should fix the problem that is what was wrong with mine. That took care of problem if that doesnt fix it the senors need to be replaced in the latch
Mar 13, 2009 | 2003 Ford F250 Super Duty Crew Cab
door ajar light
Try spraying wd40 or any rust penetrant into the door latches. Open and close the doors several times to unstick switches.
Jan 26, 2009 | 2004 Ford Explorer
door ajar
just spray so WD40 or other pen fluid into bolth door latches
spray alot to clean them out this has been a big problem with the fords and many door latches have been replaced and just could have been cleaned.
good luck
Oct 29, 2008 | 2002 Ford F150 Regular Cab
877 people viewed this tip
Top WD 40 Company Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a WD 40 Company Vehicle Part and Accessory Expert? Answer questions, earn points and help others
