Tip & How-To about Heating & Cooling
Maintenance on heating and air equipment
It is wise to have your air conditioning and heating equipment maintenanced at least one time a year. this will increase the life span of the equipment as well as find any problems that may arise before the cost gets out of hand. a wll maintained system can save on elctrical consumption and keep the home comfortable throught the year. if you have a gas furnace a carbon monoxide test should be preformed annually.
Heating & Cooling Logo
my ac stops after one hour and yellow and green lights are blinking
How to Check Your Air Conditioner Before Calling... [Edit]
Steps:
1. Change your filter regularly. This simple step alone can increase the efficiency of your air conditioner. It will also run less, increasing the life span of your equipment.
2. Wash your condenser coil regularly. Simply turn off your air conditioner, get a garden hose, and spray the coil using an "up/down" pattern. Be particularly attentive if your condenser is close to a dryer vent, or if your neighborhood is full of cottonwood trees. These two items are "air conditioner killers".
3. Look for ice around your condenser. If there is ice around the copper lines, immediately turn off your air conditioner and call for service.
4. Is the condenser and/or furnace operating at all? If not, check breakers and fuses.
Tips:
1. Maintaining your air conditioner and having it serviced regularly increases the efficiency of your unit, reduces energy usage, and prevents wear and tear on your equipment.
2. These instructions need to be modified slightly for window or "through the wall" type units.
Warnings:
1. Do not attempt any repair work unless you are a licensed heating and air conditioning technician. Most states require a licensed heating and air conditioning contractor to perform any repair work.
2. Do not attempt to add or remove refrigerant from your system unless you are licensed by the EPA. Fines and penalties await
those who tamper with or release refrigerant in an unsafe or unapproved fashion.
3. Do not attempt to diagnose any electrical problem unless you have been properly trained and/or are licensed.
4. Do not immediately assume that if your air conditioner is not working that the thermostat is at fault. Tampering with the thermostat
or is related wiring can cause more problems than you initially started with. If nothing is happening with the thermostat set,
mmediately call for service.
5. Do not bend the "fins" on the outside of the condenser. Make certain to wash the coils in an "up/down" fashion.
6. When in doubt, stop. Immediately call a licensed heating and air conditioning contractor. Did you find this Chapter Helpful? Yes No
Edit this chapter
Jul 22, 2009 | LG Heat cool Window Air Conditioner
217 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
