Tip & How-To about Computers & Internet
Steps to Delete Files Used by another Program in windows
Follow these steps to delete any files used by another program.
1. Right click the windows taskbar and open taskmanager.
2. Kill explorer.exe from the taskmanager.
3.Click file->open new task from the taskmanager window.
4. Type cmd.exe in the box and command window will come.
5. Go the directory of the file to be removed.
6. Delete the file using following command
del fileName
Computers & Internet Logo
how will solved script error "c:\windows\systems32\rahul"svirusprotection.vbe"
Rahul'sVirusprotection.vbe is a virus.
Follow the given steps to get rid of it
1) In Windows Explorer
Go to Tools -- Folder Options --View
Show hidden files and folders ---check this one
Hide prorected operation system file --Uncheck this one
2) Go to System Directoty ex: (C:\windows\ system32)
find this file "Rahul'sVirusprotection.vbe" and delete this one,
if u can't do that following the below steps
1)open the TaskManager(press control+Shift+Escapte key) then in
process Tab find ths Process "wscript.exe" and delete this one
or
2) using Unlocker 1.8.8.exe (search in Google site) for delete this
file
3) Type Regedit.exe into RUN Command
HKEY_CURRENT_USER\ SOFTWARE\ MICROSOFT\ INTERNET EXPLORER\MAIN
[Window Title = ""]
[Start Page = "www.google.com"]
HKEY_LOCAL_MACHINE\SOFTWARE\ MICROSOFT\Windows NT\ CurrentVersion
\Winlogon
[Userninit = "C:WINDOWS\system32\userinit.exe"]
Dec 22, 2010 | Computers & Internet
windows cannot find file csrcs.exe
File csrcs.exe is located in the folder C:\Windows\System32.
Program has no file description. The file is not a Windows system file. The application is loaded during the Windows boot process.
The program is not visible. It is an unknown file in the Windows folder. Program listens for or sends data on open ports to LAN or Internet. csrcs.exe is able to monitor applications, hide itself, record inputs, manipulate other programs. Therefore the technical security rating is 86% dangerous.
It simply means, "It is very dangerous"
Try these steps to remove it.
Click on START-RUN,
type regedit (it will open the registry editor)
Press Ctrl+F
type "csrcs" (without quotes) and click on Search It'll show you some results, where you'll find "csrcs.exe" delete it immediately.
Again do the same search you may see "explorer.exe csrcs.exe" , right click then modify and remove the csrcs.exe part (leave the explorer.exe as it is)
Hurray !!! you have removed csrcs.exe
Restart your system and see it for yourself
Don't forget to give feedback
Sep 05, 2009 | Computers & Internet
desktop does not show after the logon
1.This is windows explorer.exe problem
when u r logon press Ctrl+Alt+Delete
taskmanager is open click applications > new task .write explorer.exe then click ok
show ur desktop icon
2. This is windows explorer.exe problem
taskmanager is open click new . browse click desktop and right click my computer click manage local user and groups then right hand side right click user and create new user account
then restart ur system
login ur new account
May 14, 2009 | Microsoft Windows Vista Ultimate Edition
Funny UST scandal virus
first download taskiller in http://www.rsdsoft.com/task_killer/index.php4
and install it to
your computer because you cant use taskmanager to terminate the virus(the
virus automatically close taskmanager).
-run taskiller and left click it on the system tray(the one with a skull icon)
-click processes
-to close the virus, select process and click yes to the question
(process to close)
1.killer.exe
2.lsass.exe
3.smss.exe
note: close only file that have the same icon of Funny UST Scandal.avi.exe
CMD STEPS
1-now, click "start" then "run"
2-type "cmd" without quotes
3-type "cd\" without quotes
4-type "attrib -h -s smss.exe" without quotes
5-type "attrib -h -s autorun.inf" without quotes
6-type "start c:" without quotes(a new window will open)
7-select smss.exe,autorun.inf,Funny UST Scandal.avi.exe and delete it
-if theres any drive or a partition type "d:" in command prompt without quotes
"d" is the drive letter then repeat the CMD STEPS number 4-7 above.......
-now type this on the command prompt "cd windows" without quotes(na naman!)
-type "attrib -h -s smss.exe" without quotes(uli)
-type "start c:\windows" without quotes(hay naku!)
-delete the file smss.exe
-now, goto c:\documents and settings\all users\startmenu\programs\startup
-delete lsass.exe
-click "start" then "run"
-type "regedit" without quotes then delete the registry entries above....
Note:
If you have problems opening drives in My Computer open regedit find
"\smss.exe" then erase values like: "c:\smss.exe", "d:\smss.exe" etc..
Hope this helps
Jan 16, 2008 | Computer Associates eTrust PestPatrol...
funny UST scandle.avi (Virus)
I done research on this but not tested to my computer ..just try this remover created in philippines . this the link: http://www.geocities.com/six519/Remover.zip may this help.
Dec 11, 2007 | Computers & Internet
137 people viewed this tip
David Payne
David Payne
