Tip & How-To about Computers & Internet
How to Repair a Driver Problem in a Laptop
Instructions
    Windows Vista
  1. Open "Start" and click "All Programs." Select "Windows Update." Type in your account password if the operating system prompts you for it.
  2. Click the "Check For Updates" link. Select "View Available Updates" and check to see if any drivers are listed for your laptop. Click the specific driver you want to update.
  3. Click "Install." Restart the laptop after the installation finishes and see if the driver problem is resolved. Return to the "Start" menu and click "Control Panel" if the problem persists.
  4. Select "System and Maintenance." Click the "Update Device Driver" link underneath the "Device Manager" heading.
  5. Find the specific device that isn't working properly in the list of available devices. Right-click the device and choose "Update Device Driver."
  6. Windows XP
  7. Right-click the "My Computer" icon on the desktop. Click "Manage," then select "Device Manager."
  8. Scroll through the list of hardware devices being used by your laptop. Find the specific device that is having a driver problem.
  9. Right-click the name of the device and choose "Properties." Navigate to the "Driver" tab.
  10. Click "Update Driver." Select "OK" to repair the driver problem.
Computers & Internet Logo
My Toshiba statellite pro U400 is not connecting to the internet. I use windows vista. My laptop has stopped connecting to the internet and I know it is my laptop as the other computers in my home are connecting to our wireless connection. The connectivity doctor is telling me that "IP address was not set properly (c-19)" Thank you!
  • Hello Imc420, there are (4) four different ways to connect to the Internet. 1) To start, click on the "Start" button, paul7of9_20.jpg in the (right "start menu" pane), select the Control Panel 'shortcut' once the next window open; scroll to find, Network and Internet,paul7of9_21.jpg click on it to open. Next, select to open the "Internet Options." paul7of9_22.jpg To setup the Internet Connection: Click on the "Connections" block, click the ("Setup") button,paul7of9_23.jpg and follow all the instruction carefully. 2) From the "Start Menu" in the (right) pane, if you have the "Connect To: Icon, click on the icon to open; "this will start the setup and connection process." 3) Click on the "Start" button, select to open "All Programs," next scroll to find: the Product's name; example (Toshiba), click to open. "If there is a ConfigFree icon present" paul7of9_24.jpg Option is available?" select to open, and click on the Connectivity Doctor,paul7of9_25.jpg follow all instructions thereafter. (4) From the "Start Menu," click on the "All Programs" scroll to find: Accessories, select to open: if you have the [Windows Mobility Center],paul7of9_26.jpg open the program; there will be a Wireless Network 'Turn-on and Off Switch"paul7of9_27.jpg Important "Always! Click Apply, Ok, and Restart the computer after making changes to the computer." "Did this solution help?" If so, "helpful Rating Feedback appreciated, thanks paul7of9."
Jan 31, 2011 | Toshiba Satellite Pro U400-S1001V Notebook...
I have scanner LEXMARK X2690 How can I use it to scan a file?
Follow this steps on how to scan docs/files
> open the top cover, load original document facedown on the scanner glass.
>close the top cover to avoid dark edges on the scanned docs
> Make sure printer is connected to computer and both printer and computer is on.
> From the printer control panel press scan
> Follow the instructions in computer screen.
If u are using Windows
> Repeat 1 and 2 on top instructions,
Do one of the following;
> In windows vista click select all programs and then select the printer program folder from lists.
> In Windows XP click start Programs or all programs and then select the printer program folder from the list.
> Click Lexmark Productivity Studio
> On the main screen click scan
> follow the instructions on the screen..
Thanks
Nov 24, 2010 | Computers & Internet
My printer will not scan
Open the top cover, and then load an original document facedown on the scanner glass.
Close the top cover to avoid dark edges on the scanned image.
Do one of the following:
• In Windows Vista, click All Programs, and then select the printer program folder from the list.
• In Windows XP, click Start Programs or All Programs, and then select the printer program folder from the list.
Click Lexmark Productivity Studio.
On the main screen, click Scan.
Follow the instructions on the screen.
Sep 13, 2010 | Lexmark X2600 InkJet Printer
151 people viewed this tip
David Payne
David Payne
