Tip & How-To about Washing Machines
Cant find the fuse
There was a clever trick used in the electronics industry in order to make home fixs harder company started installing pico fuses they look nothing like the old glass and ceramic fuse and are now in almost all tv, washers,microwaves,dvd e.t.c this is what they look like
most common
less common
Washing Machines Logo
I'm in need of a replacement fuse for a regent ht391 home theater system ?
Local electronics shops should stock most common fuses although I know those shops are getting harder to find. There is always Digi Key Electronics Electronic Components Distributor Since 1972
Sep 04, 2016 | home Audio Players & Recorders
Battlefield: Bad Company 2 uneven sound / Fix sound problem.
I can't wait to get back home to try this. I've been battling the whole weekend on this -FRUSTRATING!!!!. Also looked at these settings in gamesettings.ini : SoundSystemSize=1 and your game will use software mode to process audio. SoundSystemSize=2 and your game will use hardware mode. SoundSystemSize=3 and it will use XFI mode. settings.ini : quality=high Very disappointed with this release as far as roll out! It looks like it's across platforms too.
Mar 04, 2010 | EA - Electronic Arts Battlefield Bad...
2003 Honda Odyssey instrument lights
There could be a defect in the driver's multiplex control unit in the driver's under-dash fuse/relay box or the dash lights brightness controller in the gauge assembly. Fuses should not be increased in size arbitrarily.
Aug 26, 2016 | 2003 Honda Odyssey
Car will not start. Gearbox fault has run disabled.
I had similar problem , its because of the security check,get a code reader erase all codes, then check if any lose connection in AC unit or head unit there are two connectors(black & White) which comes lose if you reconnecting them firmly It will do the trick hopefully
Jun 01, 2009 | 2003 Jaguar X-Type
Flyback
You can substitute a 1 amp PICO (pronounced peeko) fuse and it will work just fine. You should be able to order them anywhere. Let me know if I can be of further assistance
Dec 10, 2008 | RCA HD52W59 HDTV Projection Television
670 people viewed this tip
Top Washing Machines Experts
