Tip & How-To about Cell Phones
Network failure types
A network which contains many network components of both hardware and software can incur failures due to one (or even multiple) of its contained components incurs a failure. Ranging from the largest to the smallest and from hardware to software, network failures can be divided into the following categories:
  • Control plane failure:this type of failure is mainly related to software, i.e., network control plane software. For example, in a GMPLS-based network which is made up of a control plane and data plane, the control plane failure would lose the control of the data plane, which means that we cannot establish new service connections, or terminate or modify an existing service connections within the data plane, even though the existing connections can still perform normally to carry user's data. In other type of networks such as IP networks, the control plane failure can be even more serious. For example, the pollution of IP lookup tables at some routers would cause all the IP traffic on these nodes difficult to be forwarded. Similar stories occur for viruses attacking IP routers. They disable the IP networks through disabling IP network control plane.
  • Subnetwork failure: this is a type failure occurred with a regional subnetwork that commonly shares a risk, e.g., a region that has high occurring frequency of earthquake. In addition, some large disasters such as flooding, tsunami, etc. can also disable a regional subnetwork.
  • Node failure: this is a type of failure occurred with a single network node. The reasons for this kind of failure include accidents or disasters at a network operational center, such as power shutdown due to fire, flooding, etc.
  • Network card failure: network card failure is a type of failure under the umbrella of the node failure type. Rather than the shutdown of the whole switch node, sometimes a failure can occur only with a network interface card. For example, the failures or faults such as a laser outage, fault of a circuit board, or software bugs, etc. can also contribute to a network card failure.
  • Link failure: link failure in general is the most common network failure that occurs due to fiber cut.
  • SRLG failure: SRLG failure is a generic concept to define all types of network failures whenever a common SRLG incurs a failure. Here a SRLG can be a fiber link, node, subnetwork, or control plane, etc.
  • Single failure and multiple failures: in general network failure implies a single network failure because network failure normally seldom occurs. However, under some situations, there can be more than failure occurring with a network. This kind of situation is called multiple failure, example, dual failures and triple failures. For a network, planning for full recovery of multiple failures generally requires much high protection capacity than that of purely for a single failure.
    Cell Phones Logo
    where is the ram located on a toshiba satelite L455 S5891?
    There are usually bay doors on the underside of the laptop that contain screws to hold them in. One of these bay doors contains the RAM. Be careful when using tools to unscrew the bay doors. make sure not to use magnetic screwdrivers because there is a chance you could mess up a piece of hardware. it is also recommended that when disassembling a laptop or any PC you use an anti-static wrist strap to prevent any components from being ruined due to static shock.
    May 26, 2011 | Toshiba Computers & Internet
    What Is Network Failure
    Jan 04, 2011 | Samsung J700 Cellular Phone
    drivers for ethernet card for gateway 6433 laptop
    That unit has multiple drivers depending on os and original configuration as shipped. All are available at the mpcdrivers.com website at the following links.
    http://www.mpcdrivers.com/sylvia/Support/gateway/VIWLAN2.exe - Windows Vista Intel Wireless Network Driver version: 11.1.0.86
    Supports: Windows Vista (32-bit)
    Note: This file contains the Windows Vista network driver for the computer models and components listed below.
    3/13/2007
    190,957 KB
    http://www.mpcdrivers.com/sylvia/Support/gateway/VIWLAN.exe - Wireless Network Driver version: Intel 10.6.0.46
    Note: This file contains the Windows Vista network driver for the Gateway notebook computer models and components listed below. English, Japanese, and Spanish installation instructions are included in the file.
    2/7/2007
    3,633 KB
    http://www.mpcdrivers.com/sylvia/Support/gateway/LANFAQ.exe - LAN Windows Vista Driver Information
    Note: This document explains the networking functionality within Windows Vista for the computer models and components listed below. English, Japanese, and Spanish instructions are included in the file.
    2/1/2007
    27 KB
    http://www.mpcdrivers.com/sylvia/Support/gateway/BCM40100.exe - Broadcom Wireless Driver Version 4.100.15.5
    Supports: Windows XP
    Note: This is the Windows XP Broadcom Wireless driver for the Gateway notebook computer models listed below.
    11/28/2006
    77,858 KB
    http://www.mpcdrivers.com/sylvia/Support/gateway/D00453-001-002.exe - Network Driver version: 8.26.2.3
    Note: This is a Windows XP network driver for the Gateway notebook computer models listed below.
    Apr 16, 2010 | SMC Realtec Network Card NERENC01
    I recently bought a fake Nokia N97 and I want to get the real, updated Nokia firmware onto my new mobile phone. The phone currently has RM-233 and I want RM-237. I downloaded RM-237 onto my computer, but I'm not sure how to get it onto my phone, or if that is even possible. I need some help.
    Don't do it, it can only damage your phone and may not function anymore. Since it is fake then the hardware components inside is different from the original nokia N97. You have downloaded the original firmware which contain a program that can be used only to the original nokia N97 hardware components and system.
    Please don't do it.
    Hope this could help.
    Mar 24, 2010 | Nokia N97 Cell Phone
    199 people viewed this tip
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
