Tip & How-To about Dryers
How to Fix Dryer Lint Problems
Instructions Things You'll Need:
  • Vacuum cleaner
  • Screwdriver
  • Electric leaf blower
  1. Remove the lint trap from the dryer and peel off the accumulated fuzz.
  2. Vacuum the top of the dryer, the floor nearby and underneath for lint at least once a week. When you remove the lint trap, tiny particles fly into the air and settle nearby. Behind and underneath the dryer are favorite hiding places for dryer lint.
  3. Disconnect the vent tube from the rear of the dryer and inspect it every month. Dryer lint accumulates more easily in flexible plastic tubes than rigid aluminum ones, because curves halt the lint's path.
  4. Clean the vent tube leading to the wall annually. As for the tube leading to the exterior, a trick that sometimes works is aiming an electric leaf blower down the tube. The leaf blower can expel the lint through the exhaust on the exterior. Before using the leaf blower, check that all duct work is fastened securely.
  5. Unscrew and remove the back panel on the dryer, if you're mechanically inclined. Particles that escaped the lint trap can accumulate inside the dryer cabinet, so vacuum this area.
Dryers Logo
electrolux vacuum won't work
First check your bag. The most common problem is that the bag may be full. You will also want to check the filter. If it is neither of these things then you'll have to bring it to an authorized electrolux dealer.
Dec 24, 2011 | Eureka Oxygen 3 Ultra Canister Vacuum ...
I need instructions how to operate a shark seam cleaner SC-505C Could you please email with the instructions. I brought as a mark down at Canadian Store but the instructions were missing. I would like to have a copy of the manual on how to operate it properly.
Vera, mine just went down and I have the instructions in the bag if you would like to get a hold of me I'll send them per email. I'm new here so I don't know how this is handled, my junk mail is karmahappytoes at yahoo.com.
Oct 24, 2011 | Euro-Pro Shark SC-505 Handheld Steam...
Hi I hve 2 codes PO171 PO174 on 1995 windstar what do i need to do
Those codes indicate your Windstar is running lean so you'll have to find out why. A couple of things to check are a restricted fuel filter or a vacuum leak.
Jun 06, 2011 | Ford Windstar Cars & Trucks
is there a diagram/picture to help me visualize how to put cleaner belt back in vacuum? I was taking base of vacuum apart so I could get rid of hair that were wrapped on the roller. The cleaner belt came to loose and I could not figure how to fix it back. the model is eureka upright bagless series 430
Sorry to hear your belt fell out. Not good if you've never replaced a belt before...
Here is a website where you can read a detailed description of how to change a belt: http://www.ehow.com/how_8034505_eureka-belt-replacement-instructions.html
I don't think you'll need a photo, it's pretty straight forward. However, there are schematic diagrams for vacuums but they don't show how they go together.
If you have trouble, reply back to me and I'll try to describe for you.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Apr 21, 2011 | Eureka 431A Optima Bagless Upright Vacuum
324 people viewed this tip
Top Dryers Experts
