Tip & How-To about Computers & Internet
How to Download AMD Processor Driver!!!
Select Processor for option 1
Select the family that your AMD CPU belongs to for option 2
Now click view results.
It will then show a list of the available drivers for your processor.
Select whichever is appropriate.
Download and run the install.
Thats it!
damnor01
Computers & Internet Logo
i have an el1333g desktop it has a amd 64x2 2.4 prosscer in how much bigger can i go
Select the "Start Menu." Click to select "Control Panel." This will open a new window with several clickable options. Choose "System and Maintenance," typically located near the top left-hand corner of the Control Panel Click to select "System" from the new list of options Look for the CPU's stock speed as indicated under the "Processor" heading. This is a ballpark, relatively close estimate of your computer's CPU speed, as provided by the manufacturer. Checking the Stock CPU Speed in Windows XP Click the "Start Menu. Right-click on "My Computer." Select "Properties." By default the Properties window will usually be set to the "General" tab, but if the window is set to a different tab you'll need to click on the "General" tab located near the top of the window. Check the CPU rating as listed underneath the "Computer" heading. b> Determining Real-Time CPU Speed Go to CPU Speed Professional's website (see Below) and download "CPU Speed Professional." While other free CPU clocks exist, many are beta programs with glitches and unwanted bugs. CPU Speed Professional is well-known and reputable, receiving the "Vista 5 Star Software Award" according to its website. Install the recently downloaded " http://download.cnet.com/cpu-speed-professional/3000-2086_4-10833139.html " file by double-clicking on it and following on-screen prompts to complete the automated install procedure. Open CPU Speed Professional. Click "Test Your Speed" on the main program interface. A real-time, active measurement of your CPU speed will appear numerically, and CPU Speed Professional will also display your CPU speed on a stylish meter for easy visual comprehension. Get a Faster Processor b> Start by visiting Intel.com (see the Below ) to research and figure out which processor you want. http://www.intel.com/products/processor/index.htm Read the page and click on the links to the different processor families. Once inside the processor families you can look at the specifications and speeds of the processors. There are three main ways of determining the speed of a processor. First is the speed, measured in GHz. The higher the speed (example: 2.4 GHz) the faster the processor. Second is the L2 cache, measured in MB (example: 2 MB L2 Cache). The L2 cache is kind of like the CPU's own RAM; the larger the cache, the faster your computer operation will be. Finally, there is the Front Side Bus (FSB) speed. The FSB speed is the speed that bits of data are fed through the processor. FSB is measured in MHz (example: 1066 MHz FSB). Once you have an idea of the processor you want, continue to step two. Ensure that your processor of choice will be compatible with your current system. You can do this by checking the documentation for your motherboard. Look through the manual to find out what its CPU socket type is (example: LGA775). There can and will be different socket types on CPUs so ensure your processor choices match up with your motherboard before continuing. The socket (or package) type will be listed in the specifications of any processor you look at. Worth noting is that some motherboards also impose a limit for how high the FSB of a processor can be. While a higher FSB processor will still work with a lower FSB motherboard, processors have to go by the speed limit imposed by the motherboard. Keeping this in mind, as long as the socket type is the same on both parts, they will be compatible. Visit Newegg.com (see Below) or a similar computer or electronics store of your choice and nose around the processor section of the site. http://www.newegg.com/Store/Category.aspx?Category=34&name=CPUs-Processors You should be able to find the processor model you are after. Decide on a processor. If you've already done the research suggested in steps one and two, you should have a decent idea of the kind you want. Choose among the models you selected and add it to your cart, ensuring that the socket type of your new processor will match your motherboard. Once purchased, you should receive it within a few days.
Hope this helps.
Jan 21, 2013 | eMachines EL1333G03w (884483010820) PC...
Driver --- ATI rv6p....... please
http://support.amd.com/us/Pages/AMDSupportHub.aspx
This is a link for ATI/AMD drivers. In the upper right corner is a window"Download drivers"
1 Component catagory- click on arrow on right, scrool down to "desktop graphics", click on to select.
2 "Product line-click on and scroll down to Radeon 7xxxx series and click to select
3 "Product model-click on and scroll down to Radeon 7000 series and click to select
4 "operating system-click on and select your system
Click on "Show Results". This will give you a list of drivers for your card. Choose the first option and download. Click on run, etc. IT will get to a point where it will ask for Express or Custom install. Choose Express. Restart at finish of install.
*****Note**** you must uninstall all prior ATI/AMD software before you do this, through "programs and Features" Click on ATI Uninstaller, click on next, you want Express unistall which should remove all ATI software. Restart after uninstall the, follow steps above.
Mar 08, 2011 | ATI PowerColor RV6P-B3 RADEON 7000 PCI...
amd athlon 2800+ drivers
Click here to download the drivers for your Processor.
Select AMD Athlon 64 bit family for option 2
You would need the AMD Processor driver version 1.3.2.0053
damnor01
Dec 29, 2010 | AMD Athlon64 2800+, 1.8 GHz Athlon 64...
My Mother boards asus M4A78LT-MLE but when computer start fast screen appear " this cpu is not supports please call asus costumer care" and pres F1 enter bottom to star contnue, processor fan speed high, my processor X4 965 3.4GHZ , tell me how solve this problem?
Click here to view the list of supported processors for the ASUS M4A78LTM LE Mainboard.
The AMD AM3 Phenom 2 X4 965 3.4GHz is not supported as it is a 125Watt or 140Watt Processor.
The ASUS M4A78LTM LE Mainboard supports up and including a 95Watt Processor.
Therefore you either need to downgrade, purchase a Processor that is supported as shown in the list or purchase a Mainboard that supports your AMD AM3 Phenom 2 X4 965 3.4GHz Processor.
I myself would go for an ASUS M4A88TD-V EVO/USB3 Mainboard, its a good companion for that monster of a Processor you have got.
See if you are able to return the Mainboard and purchase the ASUS M4A88TD-V EVO/USB3
Click here for it's Specs.
There is also the cheaper ASUS M4A785TD-V EVO
Tell me how it goes!
All the Best!
damnor01
Dec 14, 2010 | ASUS M4A78LTM LE Motherboard
amd athlon xp 2400+ problems witha epox ep-8kra2+ motherboard?
It sounds to me like the processor that you bought is not fully supported in the current bios in your mobo. I would check the epox website for newer bios. Be careful flashing the bios, if you misstep in the flash, you may end up with a brick. If you are successful, you should be able to run the processor at the speeds you expected, though within the limits of the hardware on the mobo. Also look at the spec's for the mobo on the site to see if your processor is listed as being supported.
Feb 14, 2010 | EPoX EP-8KRA2+ Motherboard
1,009 people viewed this tip
David Payne
David Payne
