Tip & How-To about Computers & Internet
A boot disk (startup disk) and why you need it?
The Windows installation disc contains the files necessary to start Windows, so it is itself a boot disk. A boot disk is actually not a computer disk in the shape of a boot. If it was, most disk drives would have a difficult time reading it. Instead, a boot disk is a disk that a computer can start up or "boot" from. If a problem is preventing Windows from starting, you can use the installation CD to start Windows. The installation CD also contains Startup Repair, which you can use to repair Windows if a problem prevents it from starting correctly. Startup Repair can automatically fix many of the problems that in the past required a boot disk to fix.
A boot disk (sometimes called a startup disk) is a type of removable media, such as a floppy disk or a CD, that contains startup files that your computer can use to start Windows. CD and DVD boot disks are often used to start up a computer when the operating system on the internal hard drive won't load.The startup files are also stored on your computer's hard disk, but if those startup files become damaged, you can use the files on a boot disk to start Windows
Earlier operating systems that used the FAT or FAT32 file systems, such as Windows 95 and Windows 98, a boot disk was especially useful because it allowed a person to access files on a hard disk even if Windows was unable to start. This ability also represented a security risk, because anyone with a boot disk and access to the computer could start the computer and access any file. Hard disks formatted with NTFS have built-in security features that prevent using a boot disk to access files..
Let looks at some useful "boot CD downloads" to create one for Windows OS,s.
1-Ultimate Boot CD for Windows - This BartPE-based boot disc comes with a huge selection of tools to access your data and get your PC booting properly again. Some of them are even useful.UBCD takes a long time to load and asks you some odd questions before it's finally up. But once it's there, you can edit the Windows Registry (yes, the one on the hard drive) in RegEdit, recover deleted files, and even run benchmarks. setting up UBCD is identical to creating a BartPE disc--with the same possibility of failure. But when it works, you get a lot more.Price: Free
Download Ultimate Boot CD for Windows.
2-Puppy Linux - A third party application to create a boot CD using Linux and great for accessing NTFS-formatted hard drives--especially if you're not comfortable with Linux's whole mount concept. Just open the Drives window and select a drive, and Puppy will mount it for you--in read/write mode, if possible.Puppy will mounting the drive with read/write permissions and you not only can copy your files elsewhere, but you can also edit them. Puppy Linux comes with AbiWord, which supports .doc files, and Gnumeric, which supports .xls. And even if it mounts read-only, you can still copy the files to an external drive, most of which are formatted in the universally accessible FAT32 file system.
But be careful how you click. Actions that take double-clicks in Windows, such as opening a file, take only one in Puppy.
Price: Free
Download Puppy Linux.
3-BartPE - The BartPE operating system makes a pretty good boot disc on its own, getting you into Windows and letting you access your drive. It doesn't have much in the way of repair utilities, but it has chkdsk, which should probably be the first one you try.To create a CD, the program needs the Windows 2000 or XP installation files. One place you're sure to find them is an actual Windows installation CD-ROM. But the recovery disc that came with your PC probably doesn't have them.
Luckily, if your PC came with XP installed (and thus, not with a true XP CD), the necessary files are probably in a folder called C:\Windows\i386. But I do mean probably, not definitely. However, since the PE Builder is free, you're not losing much if it can't create a disc.
Price: Free
Download BartPE.
4-Vista Recovery Disc - a unique distribution of Microsoft's own recovery tools.This Recovery Disc is basically a Vista installation disc minus the install files. It even has an "Install now" button that asks for a Product Key before failing. You're better off clicking the Repair your computer button. Among its Vista-only options are a tool for diagnosing and fixing startup problems, a version of System Restore that uses restore points on the hard drive, the restore portions of Vista's backup program, and a memory diagnostic tool. Price: Free
Download Vista Recovery Disc.
5-Trinity Rescue Kit - TRK's command line interface could humble anyone but the most devoted Linux geek.
If you take the time to read the 46-page documentation and learn the program, you'll be rewarded next time disaster strikes. Among the tools that will be at your disposal are a script that runs 4 different malware scanners, a tool for resetting passwords, a Registry editor, a program that clones an NTFS partition to another PC over a network, a mass undeleter that tries to recover every deleted file on the drive, several tools for recovering data off a formatted or dying disk, two tools for fixing master boot record repair programs, and hardware diagnostics.
Price: Free
Download Trinity Rescue Kit.
Hope that you understand the benefits of having a boot disk on your wardrobe.
Computers & Internet Logo
is this computer able to dual boot win 7 and xp
Which version of xp are you trying to install 32 or 64 bit ?
Your ability to install a second operating system on your Windows 7 system hinges on one thing: partitions. If your computer has only one partition, you can't dual-boot your system without erasing all information on your computer. Two hard drives, or two partitions, enables you to dual boot. Check this information first, before proceeding.
Click "Start" and type "disk management" into the search bar. Click on "Create and format hard disk partitions" in the list of programs to open "Disk Management." Look at the list of partitions and available drives. The information here will be different on every computer. "C" is your primary hard drive and active operating system partition, and this drive contains your Windows 7 installation. You can't install Windows XP here without formatting the system. Check for secondary drives and partitions in Disk Management. Your system may have a "D" or "E" drive. Some computer manufacturers create a hidden partition with recovery software: don't remove this partition. If you have a secondary partition called "D" with more than 2GB of free space, you can install Windows XP here. b> Installing XP b> Insert the Windows XP Setup disc into your CD or DVD drive and close any windows that appear. Shut down your computer with the disc in the drive. Turn the computer on and look for a message saying "press any key to book from CD." Press any key on your keyboard when this message appears. Most computers are configured to look to the CD or DVD drive first, before booting to the operating system. If your system doesn't recognize the disc, you will have to enter your BIOS and change the boot order. Look to your manual for information on changing the boot order. Press "Enter" on the "Welcome to Setup" screen to load the Windows XP setup program. Read the license agreement and press "F8" to accept. Windows will detect that an operating system is already installed on your primary partition and present a list of other partitions to install XP. Use the arrow keys to select your secondary partition ("D") and press "Enter" to confirm that you want to install XP here. Then choose what to do with the partition: leave the file system intact or format the partition using FAT32 or NTFS. Windows XP supports both file systems, but requires NTFS on partitions larger than 32GB. You don't need to format the drive to install XP. Follow the prompts on screen to enter your personal information, serial number, and date and time. The setup program copies files to your PC and reboots -- don't press a key to boot to the CD. When you have to operating systems installed, a DOS screen appears asking you to choose an OS; press the down arrow key to highlight Windows XP and press enter to complete the setup. You will have to choose this every time to boot into XP, otherwise your computer will boot to Windows 7 by default. Hope this helps.
b>
Jan 06, 2013 | HEWLETT-PACKARD Pavilion Desktop with AMD...
i want to formate my system how can i do it instruct me...and will my genune copy of windows be tutelly removed
First of all, no your windows operating system key would not be removed because your hardware is already register to your computer. Yes by formatting your computer, you will loose everything and every single files, including the o.s. If you want to format and You want to restore your computer to factory setting, you will need to make a restore/recovery disk provide in the acer management program. You will see a option for making a backup disk in the acer management software in the start menua via all programs. After making this disc, save all the files that you want like pic,music,video,doc to an external harddrive. Insert disc or simply leave disc, Turn of you computer, setup your bios to boot from cd/dvd-disc in the bios boot menu. (should see this option when starting up the first few second, maybe a F key or DEl key to get you into the bios menu or A key saying boot option) Set your boot prority to cd/dvd. The Acer recovery program will come on and follow direction. If you just want to format everything and not making a recovery/restore disk (which I would not recommend unless you bought another windows operating system disc). Then just click my computer and locate your harddrive, Right click, format, you should be good to go. You will loose everything.
Jan 27, 2011 | Acer Aspire 5742Z-4200 Notebook
windows boot manager
Hit F8 a few times while your computer starts to boot, a boot selection screen should come up. Try selecting "Last Known Good Configuration" and see if you can boot up without running the repair install.
Sep 02, 2009 | Toshiba Satellite P205-S6287 Notebook PC
no boot sector on internal hard drive. No bootable
A boot sector is a sector of a hard disk that contains booting programs stored in the other part of the hard disk. You boot sector might have been deleted or corrupted and you can't logon until you repair or recover the boot sector. To do this you must have your OS cd. Boot from OS cd the follow below steps...
Windows Vista
1. Insert the installation disc.
2. Restart your computer
3. If prompted, press any key to start Windows from the installation disc.
4. Choose your language settings, and then click Next.
5. Click Repair your computer.
6. Select the operating system you want to repair, and then click Next.
7.
On the System Recovery Options menu, click Startup Repair. Startup Repair might prompt you to make choices as it tries to fix the problem, and if necessary, it might restart your computer as it makes repairs.
Boot from you hard disk then you're done!
Regards,
Jeep Brainy
Jul 29, 2009 | Dell Inspiron 6000 Notebook
235 people viewed this tip
David Payne
David Payne
