Tip & How-To about Sony Playstation 3 (PS3) Console
The Awesome way to fix your PS3 that wont read discs
First try this if it does not work try doing my way of fixing it
This is what the PlayStation Forum says:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore
Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
MY WAY
Sign in
Update your PS3 (in the settings menu the 1st option)
go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as well as cookies
check the disc if it has fingerprints or scratches if it does then thats your problem
if you have the 60GB sos mate they have alot of problems
or maybe try this put the PS3 on then press the eject button (with no disc in) then hold it then switch the PS3 off at the back with your finger on the eject button still holding it then put it back on then the fan test should be working this may cool it down
it may be overheating
if this problem still continues go out and buy a inter cooler from a shop
if it STILL CARRIES ON phone up sony
Sony Playstation 3 (PS3) Console Logo
I was on play station and then suddenly it got stuck so I turned it off and then I turned it on. When it was on i went to iniciate session on play station network and it said error 8002A203 and y went to formate the hard disc of the play station and i havn't formateated yet because it says: Do you want to formateate? and you can say yes or no and if you say no then the playstation says: It couldn't find any hard disk. So I don't know what to do... Can you help me to fix it?
***PlayStation Network Maintenance on March 9, 2011*** Answer ID: 312 Product: PlayStation®Network-Network Status
The PlayStation Network will be taken offline for maintenance on Wednesday, March 9, 2011, for approximately 11 hours during the following maintenance window:
Down Time (Start): Wednesday, March 9, 8:00 AM, Pacific Time
Down Time (End): Wednesday, March 9, 7:00 PM, Pacific Time
During this time you may:
  • Not be able to access the PlayStation®Store
  • Have difficulty signing in to the PlayStation®Network
  • Not be able to play online games
  • See a maintenance page when attempting to access the PlayStation®Network
Mar 09, 2011 | Video Game Consoles & Games
what does the error code 8002A203 mean and how can i fix it?
Mar 09, 2011 | Sony Playstation 3 (PS3) Console
how to reset an ps3 controller ? ive done da resset button thing but it dont work
You can also try the steps below. Its from PlayStation Forum:
• Restore Default Settings: Reset all system settings back to default.
Good luck.
May 30, 2010 | Sony Playstation 3 (PS3) Console
My ps3 frooze up after i downloaded the update. Now it does not move from the other OS question. How do i proceed from here?
You can try the steps below. Its from PlayStation Forum:
• Rebuild Database2_bing.gif: Rebuilds the OS for the PLAYSTATION®3.
Apr 11, 2010 | Sony Playstation 3 (PS3) Console
How do you fix the problem when a game in turned off in the middle and the playstation says memory corrupt
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with
your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
I wish you good luck.
Mar 24, 2010 | Sony Playstation 3 (PS3) Console
806 people viewed this tip
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
