Tip for 24032 \ 24036 Top Load Washer
Washer Overflows
posted on Jul 09, 2008
jsrock516
jsrock516
Rank: Guru
Rating: 96%, 7310 votes
This advice is for a washer that fills and will not shut off, resulting in an overflow. Or, water is leaking from the washer while filling. The symptoms can apply to either a TOP LOADER or FRONT LOADER washer. This may be able to save you from an expensive service call by making these simple visual checks.
Water Does Not Shut Off and Overflows: The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
Water Leaking While Filling: The other end of this hose runs to the air dome fitting on the side of the wash tub. If the lower end of the hose comes off, the water will begin to spill onto the floor under the washer, but the tub will not fill.
What to Look For: Check for the obvious. Make sure the air hose is still attached to the pressure switch and air dome. Then, inspect the entire length of the hose, paying particular attention to areas where chaffing may occur and at the points where the hose connects to the pressure switch and air dome. Vibrations from the washer can cause some wear if the hose is rubbing against anything, and the ends of the hose can stretch over time and not seal properly.
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the “Load Level”, “Load Size” or “Water Level”. On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½” off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful and saves many of you a future service call.
Very Helpful
Was this helpful?
Yes
No
6 people thought this was helpful
Comments
- Nov 16, 2009
OMG! you are the Guru. I have asked just ask online no real help. However, you described the hose i was wondering about it was not attached i guess due to the teenagers over filling the machine making it off balance and it vibrated off. So, first i reattached it nothing then I cut the end like you said and reattached it yay! finally sucess.
sincerely a single mom on a budget.
- Aug 18, 2008
Hi JS,
This is nothing to do with the overflowing problem, but its the only post I found you on...
I asked you in July how to replace the bearings on my Hotpoint FEW12P... you sent a 4 page step by step instruction sheet and we followed it to the letter.
You are an ABSOLUTE STAR!!!!
Thankyou so much.. it was so good having your words backing up what we saw, and when it came to replacing the belt, it was a God Send, as Bob was convinced something hadnt gone in the right place, it was such a stretch.. I read your comment that it takes some effort. We had already tried 3 times and no avail. Went back after your encouragement and it went on first time.. Fear really gets in the way!
Thank you again love. I wish I could be as much help to you as you have been to us.
Bless your Cotton Socks.
Sending you a mega hug
Sue x
Featured Tip
nxt prv
Add a Comment
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
Can you Help with these Washing Machines problems?
Answer
loose part in washer small metal clamp half circular aprx 1in in diameter -
Answer
There is a loud knocking sound during the rinse and spin cycle. It comes and goes.
Answer
my dryer is running but no heat. its a gas dryer. already checked circuit breaker.
Answer
washer stops before rising and shows error code 06
Answer
1 my wm is not draining all the water out i have 2 spin my clothes 3 times before i can take them... (More)
Describe your problem:
Select a Category:
Insert Link
Insert Image
Insert List
Insert List
Spell Check
What is this?
Select
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
