Tip & How-To about Computers & Internet
Read a PDF without installing software - all browsers
1.at google documment Click on the Import button.
2.Click on the button Select files to import.
3.Select to open the PDF file and click Open.
4.Click Start import.
5.Click then the file imported.
6.The PDF file is then opened and displayed in Google Docs. You can browse, print, etc..
Computers & Internet Logo
i want to move outlook personal folders from pc
Export it first from outlook for a current copy making sure you check mark "include sub folders"- then copy it to the taget PC, then import it back on the new pc from import/export in Outlook.
Make sure you get all of the personal folders, contacts etc.
if you need the steps how to do it, here they are:
To export an individual Outlook folder, such as the Contacts folder or the Calendar folder, follow these steps:
1. On the File menu, click Import And Export.
2. Click Export To File, and then click Next.
3. In Create a file of type click Personal Folder File (.pst), and then click Next.
4. In Select the folder to export from, click the folder you want to export. Click to select Include Subfolders if it applies, and then click Next.
5. In Save exported file as, click Browse to select the location of the .pst file to receive the data that you want to export. Or, type the path and file name, and then click Finish.
How to import .pst file data
To import a .pst file into Outlook, follow these steps: 1. On the File menu, click Import And Export.
2. Click Import from another program or file, and then click Next.
3. In Select the file type to import from, click Personal Folder File (.pst), and then click Next.
4. In File to Import, click Browse to locate the .pst file that you want to import, and then click Next. If you know the path, type it in the box.
5. In Select the folder to import from, click the folder that contains the data that you want to import.
If the folder contains subfolders, and you want to include this data in the import process, click to select the Include Subfolders check box. If the destination for importing is the currently selected folder, click Import items into the current folder. Otherwise, click Import items into the same folder. This creates matching items in the destination folder that you select.
6. Click Finish.
and also try this link Hope this helps,
Thanks,
Prem
Feb 18, 2009 | Microsoft Office Outlook 2003 for PC
CSV file to Import correctly into Excel 2003
Rudils,
The key is to import the data and not open the file directly.
1. Open a Blank Workbook in Excel.
2. Data, Get External Data, Import Data. (Excel 2007 is Data, Get External Data, Data from Text)
3. Browse to your .csv file and Select "Import".
4. Import Wizard should appear.
5. Page 1 Select "Delimited"
6. Select the row which you want to start the import.
7. click "Next"
8. In the Delimiters, select "semicolon" and/or other delimiters you are using.
Note: The bottom half of the window will preview the way the data is to be imported.
9. click "Next"
10. highlight each column of your data in the window below. For each column you can specify "General", "Text", "Data", or "do not import column" using the radio buttons in the top left of the Wizard box. This is an optional step.
11. Click Finish.
I hope that helps. Please add a comment if it not clear.
kpenguin
Nov 22, 2007 | Microsoft Excel for PC
117 people viewed this tip
David Payne
David Payne
