Tip & How-To about Computers & Internet
How to Install Speakers on your Computer/Laptop!!!
At the rear of your computer you will find the I/O, this is known as the In/Out of your computer mainboard.
Here you will find various input and output ports, these include USB, VGA out, DVI, HDMI, Firewire, e-sata, audio in/out, PS2 for mouse/keyboard, etc...
In this case we want to connect speakers to our computer, so we want to find the audio out 3.5mm jack. It is colour coded GREEN. Insert the speaker connector into the GREEN 3.5mm jack.
If you have a sound card installed you will need to plug the speaker connector into it's GREEN 3.5mm jack.
Below: The I/O of your Computer Mainboard, the red elipsis indicates the audio in/out. We are going to be using the GREEN one shown!
If at this point you don't get any sound from the speakers you will need to install the audio drivers for your specific computer mainboard/sound card.
Use the CD provided with your Mainboard/Sound Card alternatively use Google!
Happy Listening!
damnor01
Computers & Internet Logo
where is the body control module located on 2002 cadillac deville
The body control system consists of the following 3 modules:
• The Dash Integration Module (DIM)
• The Instrument Panel Module (IPM)
• The Rear Integration Module (RIM)
Each of the 3 body control modules integrate a number of functional systems under the control of a single module. Each module is connected to the Class 2 serial data circuit, many of the control functions are implemented by Class 2 messages.
What system (S) are you having problems with ?
The various RIM inputs and outputs are described in the corresponding functional areas as indicated on the RIM electrical schematics.
The RIM functions include the following:
• Automatic level control
• CIGAR relay control
• Class 2 communication requiring RIM interaction
• Content theft deterrent
• Fuel door control
• Fuel level sensor input
• Heated seat control
• HVAC blower control
• LK/CYL relay control
• Park brake relay control
• Rear defog relay control
• Rear park assist chime control
• Retained accessory power (RAP) relay control
• Reverse relay control
• Transmission shift inhibit
• Trunk release relay control
• Various controls for the interior lamps
Instrument Panel Integration Module (IPM)
The various IPM input and output circuits are described in the corresponding areas as indicated on the IPM electrical schematics.
The IPM functions include the following:
• 54 volt VF display input
• Ambient light sensor input
• Class 2 communication requiring IPM interaction
• Fog lamp switch inputs
• Front HVAC air delivery controls
• Front HVAC sensor inputs
• Front HVAC temperature controls
• Fuel door and rear compartment lid release switch input
• Hazard switch input
• HUD active control
• Instrument panel lamps dimmer switch input
• Ignition switch headlight control
• Interior lamps switch input
• Key in ignition switch input
• Traction control switch input
• Twilight sentinel delay input
The various DIM input and output circuits are described in the corresponding functional areas as indicated on the DIM electrical schematics.
The DIM functions include the following:
• Class 2 communication requiring DIM interaction.
• Control of exterior lamps.
• Control of front fog lights.
• Control of the headlights.
• Headlamps on with wiper input.
• Hood ajar switch input w/export.
• Horn relay control.
• Interior lamps incandescent dimming.
• Low side temperature for HVAC compressor.
• Power moding control over Class 2 serial data circuit.
• Reverse lockout solenoid control.
• Steering wheel controls input.
• Storage of the clock settings and, sending a message out on the class 2 serial data circuit in response to requests from other modules.
Jun 19, 2017 | Cadillac Cars & Trucks
acer monitor no signal
If your monitor has various input sources, make sure it's on the correct input source in the main/input menu. If that's not the problem double check the cable for bent pins also make sure if you have a video card with DUAL dvi outputs that your using the correct one.. as the other one might be secondary and non-functional. It's possible but highly unlikely if you unplugged the DVI cable while the monitored was still powered on it could have damaged the video card of the computer or mainboard of the LCD monitor. When in doubt try another DVI cable if all else fails.. if you have another DVI monitor (thats a known good) try that also to make sure that the video card is not the problem.
Nov 05, 2013 | Acer H243H Monitor
BIOS DEFINATION
Basic Input Output Service....It is the chip on motherboard ,in which all instruction written for identifying the hardware
Dec 03, 2008 | Computers & Internet
DC Power jack broken
Looks like you're right, I did not see any Lenovo replacement jacks either. You might try looking at the IBM Thinkpad jacks for various models to see if you can find the same jack.
I've repaired 3 laptops with this problem. Rather than replacing the jack on the mainboard I wired a "pigtail" to the mainboard and then zip tied a female connector to the back of the laptop itself. I did this because the mainboards were pretty beat up from the heat the original jack produced as it began to loosen. The end result is not as pretty as the original jack, but it absolutely takes all the stress off the mainboard. Those computers will never have this problem again.
Good luck.
Dec 09, 2007 | Lenovo 3000 V100 Notebook
428 people viewed this tip
David Payne
David Payne
