Tip & How-To about Video Game Consoles & Games
GOLF TIPS
How To Play Wii Golf without Maps or Meters:
The power meter, map, and wind speed indicator can be disabled by pressing and holding the 2 button. Then make a selection at the "Select a Course" screen.
Video Game Consoles & Games Logo
How do I change from meters to yards?
In the manual.
From the Play Golf Menu, highlight the option using the
/ buttons then press the button. Toggle between Yards
& Meters with the / buttons, and confirm the preferred
measurement setting by pressing the button
GolfBuddy Global Accuracy Matters
Dec 29, 2015 | GolfBuddy Golf Buddy VOICE GPS
Need to go back to yards from meters
To select between yards and meters, press and hold the POWER/FIRE button
Oct 27, 2014 | Bushnell Golf Tour v3 Slope Patriot Pack...
v3 change meters to yards
MODE and UNIT OF MEASURE OPTIONS
The TOUR V3 can be used to measure distances in yards or meters. The unit of measure indicators are located in the lower
right portion of the LCD. To select between yards and meters, press and hold the POWER/FIRE button. The display will
begin to cycle through the setup options: Yards w/JOLT, Yards, Meters w/JOLT, Meters (for details on the JOLT feature,
see "About JOLT"). When the units and JOLT mode you want to use are displayed, release the POWER/FIRE button to
select it. If you are changing from yards to meters, a change in unit of measure will be indicated by the illumination of the
M for meter indicator while the Y for Yard indicator is turned off. If you are changing from meters to yards, the opposite
will occur. The TOUR V3 will return to the last unit of measure setting used each time the unit is turned on.
Aug 03, 2014 | Bushnell Tour v3 Rangefinder With Slope
Golf Buddy Voice
Press and hold the Plus button while on the play screen.
May 11, 2013 | Golf
Changing Modes
press the power button to turn the unit on then, while looking through the monocular, press and hold the mode button for 5 seconds. You will see the unit of measure indicator switch from meters to yards. Good Luck!
Apr 14, 2007 | Bushnell Yardage Pro 800 Compact...
585 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
