Tip & How-To about Dryers
Kitchen aid Pro line front load gas and electric dryer fault code
PF- Power failure. Recommend that you press and hold the start button to continue the cycle or press off to clear the display.
E1- Open temp sensor Recommend that you replace the temperature sensor
E2- Shorted Tempurature sensor. Recommend that you replace the Temp sensor.
E-3- Blower rotation failure.Recommend you check the motor and replace if needed.
E-4 Tumbler rotation failure.Recommend you check the motor power.
E-5 Dry rack sensor error.recommend that you check the sensor and replace if needed
E-6 Exhaust high limit fault. Recommend that you check your exhaust and clean if need or replace the sensor
Dryers Logo
My LG comes up with the error code PF
PF - Power Failure - PF error code indicates a power failure during the washer's cycle.
Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks
Oct 23, 2011 | LG WM-2277HW Front Load Washer
I have a whirlpool duet # gew9250pw1 it won't
my whirlpool dryer has power but does not start
Jul 02, 2011 | Whirlpool Dryers
kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 15, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer
Error codes. are any of these lit? PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display. E1 Thermistor open Replace thermistor if found defective E2 Thermistor shorted Replace thermistor if found defective
Sep 12, 2007 | Kenmore 82836 Gas Dryer
Whirlpool Duet Electric Dryer will not get hot
Here are the source codes that pop up on the dryer with the "fix" PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display. E1 Thermistor open Replace thermistor if found defective E2 Thermistor shorted Replace thermistor if found defective
Sep 12, 2007 | Whirlpool Duet GHW9150P Front Load Washer
298 people viewed this tip
Top Dryers Experts
Dan Webster
Dan Webster
